Agitator Won't Work
I have a Whirlpool Ultimate Care II Model: LSQ8543JQ1, Serial: CL 0718595 Type: 111 and just within the last couple weeks it won't agitate unless you grab it at the top and help it. Then it stops again and shakes. What do you suggest to correct the problem? Thanks in advance, Matt
  • 1 more comment
  • Matt Mundorf Sep 08, 2007
    It does look like it's a 2 piece agitator. Does it take much to disassemble it to see if the gears are stripped?
  • Matt Mundorf Sep 10, 2007
    MAN! I've been fighting to pull the top away from the bottom and had no luck. How the heck can I get the Auger pulled apart from the agitator?
    Thanks for all your help.
  • Matt Mundorf Sep 11, 2007
    I ended up banging it upside down for a while and it finally came apart. It was the "cam dogs" that were worn out. Replaced them and it's up and running again.
    Thanks for your help,
  • 291 Answers
I not sure but sounds like u have a 2 piece agitator... sounds like gears in top of agitator is stripped.. you can replace them for few bucks ... if its a 2 piece agi.
Posted on Sep 07, 2007
  • Mike Johnson
    Mike Johnson Sep 09, 2007
    No easy to do... piece of cake..
    Its the Only thing it can be.. take off lid top with a knife or something thin, loosen bolt.. 7/16... pull agitator off seperate and u will find the gears replace gears and like new again.. gears should only be few bucks
  • Mike Johnson
    Mike Johnson Sep 10, 2007
    I just stand on it ... pull up and wiggle it some .. got a couple of tap ears on it that holds it just wiggle alittle back and forth while standing on the bottom of it
You can buy the entire agitator assembly from here:
It looks like it is the lower agitator and the upper part with the cam pieces already put together. I couldn't see how to disassemble my top part in order to get to the cam. The plastic tabs are all worn down that connect the top part to the lower agitator part. By ordering the entire assembly it will cost more but will save me a big headache.
Posted on Jan 30, 2008
I have a Whirlpool Ulitimate II Washing Machine problem. Model LSQ9010KQ0 Serial CM2756127 Type 111. Seems to be working fine expect that after the spin cycle the clothes are still pretty wet. Water is...
It sounds like what you're describing is a weak clutch. The clutch could be worn & slipping or may have oil residue on the clutch pads. I would recommend replacing the clutch. Here is a link to the part.
Jan 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not drain
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator won't work on last cycle
go to enter your model number and look for part # 470910. this is a tricky part to replace
Apr 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer Won't Agitate
It might be the agitator dogs. Try to replace those
Feb 06, 2009 | Whirlpool LSQ8543J
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wobbly agitator
If you remove the center cap from the agitator there should be either a bolt or a square recessed socket that you can attempt to tighten. The bolt is either 7/16" or 1/2". The recessed socket can be tightened using a 3/8" to 1/2" socket adapter.
Make sure the agitator is seated properly on the center post. You can accomplish this by finding the mounting bolt and loosening it enough to free the agitator on the post and push down evenly on the bottom flanges at the base of the agitator where it meets to bottom of the tub.
Try this and let me know if it helps. Post back if you need further assistance.
Feb 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I would make sure that the washer is properly leveled, and ensure that all sensors that check if the door is closed are working properly.
Sep 07, 2007 | Estate TAWB600JQ Top Load Washer
Washing Machines Logo
570 people viewed this question
Top Washing Machines Experts
