Back to:
Tags:
Standard Televisions
Generic problem for all Standard Televisions
Smart lock access code on tv (by 7 users)
posted by pookstermama on Sep 07, 2007
Grandkids playing with Magnavox Tv control and set smart lock. Don't know what the code number they entered, need to know if there is a way to reset the tv without the code.
Comment by pookstermama, posted on Sep 07, 2007
The model number is: MS2730C221, hope this helps narrow it down further. Thanks.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by Guest, posted on Mar 16, 2008
my tv is locked and i need to unlock it
Comment by fefe1, posted on Nov 17, 2007
reset code
Comment by Tn Hillbilly, posted on Nov 16, 2007
I have a Symphonic TV, MODEL # WF2702, SER # V18275143, manufactured in May 2002. It has a parental code entered...have no idea what it is....how do I unlock the control?
Comment by Guest, posted on Nov 16, 2007
have
Comment by Guest, posted on Nov 04, 2007
key lok for sanaui svt34nc2a
Best Solution
FixYa! (100)
ElecEngTech
Rank:Master Master
Rating: 91%, 55 votes
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number.
If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental
Access Code.
Comment by ElecEngTech, posted on Sep 08, 2007
You will probably have to perform all three steps below. Just follow the steps carefully and you should be up and running again. Thanks for the model number.
1) To reset/change the SMART LOCK code, follow these steps.
Press the MENU button on the remote to display the on-screen menu.
Press the Cursor Up (also known as CH + button, above menu button) or Cursor Down (CH - below the menu button) to highlight SMART LOCK. Then press the Cursor Right (VOL + button to right of menu button) to display the SmartLock ACCESS CODE screen.
Using the numbers on the remote keypad, enter 0 7 1 1. " INCORRECT CODE" will appear on the screen. Enter the code 0 7 1 1 again.
Cursor Down to CHANGE CODE and enter 0 7 1 1 and then CONFIRM CODE and enter 0 7 1 1.
Press the STATUS / EXIT button (left of CH +) to save the new code in memory.
2) If the grandkids have locked out any channels, then you will have to perform the following steps:
Press MENU, highlight SMART LOCK, right arrow, enter 0 7 1 1, confirm by entering 0 7 1 1 again.
Cursor to BLOCKING OPTIONS, right arrow, and highlight CLEAR ALL, right arrow.
You should then see CHANNEL....ALL, LOCK....YES, ALL UNLOCKED.
3) To turn SMART LOCK off, follow these steps.
Cursor to BLOCKING OPTIONS, right arrow, and highlight BLOCKING OPTIONS, right arrow,
MASTER DISABLE. Use Cursor Right (VOL +) or Cursor Left (VOL -) to select OFF.
You should see MASTER DISABLE....ON (which means SMART LOCK is turned off.)
Oops, correction to step 3)
....MASTER DISABLE. Use Cursor Right (VOL +) or Cursor Left (VOL -) to select ON (not the typo OFF.)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Smart lock access code on tv:
I don't want to Accept this solution
Solution #2
posted on Apr 02, 2008
FixYa! (100)
grains
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
magnavox-serial #DN1A0539111428, model #13MT141/17, use the following passwords still was unable to unlock channel.
Thank You!
Can you Help with these Standard Televisions problems?
Mitsubishi CS-32307 32" TV
I have a mitsubishi cs-32307 tv with no remote. Can you...
Philips 25PS40S 25" TV
I just purchased a used philips tv, model # 25ps40s121...
Philips 20PT6441 20" TV
Each time it powers up, but screen is all static and no...
Zenith C27A24T 27" TV
When the tv is on from a cold start, the picture is fine,...
RCA P60828 TV
Hi I have the same convergence issue that it seems all RCA...
6 Other Users Have The Same Problem - Continued
key lock for sansui stv34nc2a
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
