Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Able to send fax cannot receive fax
The line keeps ringing. The sender calls saying they are trying to send fax but unsuccessful.
    Problem Solver:
  • 19 Answers
Make sure phone line is pluged into line on fax,make sure fax is set auto.there should be a button on fax panel that say's receive mode.
Posted on Sep 24, 2007
  • joe giani Sep 24, 2007
    if that does'nt help you can do a memory clear,that machine sometimes gets confused and resetting to factory setting might work.
SOURCE:
Cannon Fax Machine Super G3 Unable to send. Phone rings but does not send. No error message.
In order to send, the recieving machine and the sending machine need to handshake (agree on setting, etc.)
If, as your description says the phone is ringing, I presume your are the sender.....what you need to hear is the other machine pick up, and then fax screech noises..... Test by calling the receiving fax by regular phone, and you should hear a pickup and fax noises....if not, your machine would never send.
Mar 26, 2011 | Computers & Internet
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
Stopped receiving faxes ten days ago. Can still send faxes. Senders say it just rings and rings. Calling the fax by phone confirms many rings, then fax belltones. What do you think is the problem?
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 28, 2010 | Canon PIXMA MX310 All-In-One Printer
Fax machine will not receive a fax
try switching the fax with a phone and calling... that phone with your cell... see if you have static... if you have static on the line... then call your phone company and have them fix the line... or try putting a magnet filter on the line... next reconnect your fax and call... if your phone line is ok... and it just keeps ringing.... adjust the ring wait time to 2.... if thats doesn't help... you have a bad mainboard...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 10, 2009 | Brother IntelliFax-2820 Laser Fax
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Cannot recieve faxes
you need to watch during ringing period need to click ok or press what ever message says.
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
Receiving Faxes
Can you receive a voice call on the same line? Call the machine with your cell phone and see if it rings and you can hear your voice on the fax receiver. Use your manual to check the settings.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Feb 23, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
163 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
