Question about Kenmore 73189 Air Conditioner
No Power to unit
Hello, AC was working fine. All of a sudden it died. We checked that there is power to the unit. We've ordered a new control box. Do you think replacing this would fix the problem? Also, do you know how hard a task replacing the control box is?
  • kaminate Jun 27, 2008
    There seems to be no power going to the unit.  I've used other appliances in the outlet and checked the circuit breaker.  The problem appears to be with the unit itself as it won't work in other outlets either.
    Novelist:
  • 75 Answers
Hi, How old is the unit? Is there a warrenty on it. If so, anything you do to it may void the warrenty. First, check to make sure breaker on the end of the plug is not tripped. It will probably have a reset button on it. If it will not reset it can be replaced with a regular 110 plug if needed. (If this is a 110 unit) If you are talking about the control panel on the AC when you say control box I think you are getting into more than you can handle and not sure that what you ordered is even what you need. If you want to get into it, first make sure it is unplugged, Take off the front cover and slide the unit from the outer cover, there may need to be a few screws removed to do this. Look at the wiring and see if there is anything burned or loose. Other than this you would have to get a meter and talk with someone on here familiar with your particular unit to troubleshoot it. I really don't think you should order any parts before you find out what the problem is. If there isn't anything that you can see that's wrong with it I would suggest taking it to Sears and letting then determine if it would be better to fix it or replace it. Hope I have helped. kstfas
Posted on Sep 08, 2007
SOURCE:
Blower not working. How to test
if the blower is working when you jumper it at the motor you`ve eliminated the motor itself.if you have replaced the heater control with a new one or known good used one then the only thing is the blower motor resistor has gone bad.i`m surprised you did not check and replace this unit after jumping the blower motor.
Nov 04, 2013 | 2005 Chevrolet Impala
My AC unit just died out of the blue.
Sounds more like a bad breaker possiably not getting power to your unit I would check the breaker first
Jul 21, 2013 | GE "General Electric AEN10AQ 10,000 BTU...
Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Jul 11, 2012 | Intertherm Heating & Cooling
Lost power to ac/heat control.
prob. a bad a/c control head
Jun 15, 2012 | 1993 Chevrolet Suburban
My old Kenmore window unit has all of a sudden stopped working. Was working fine then just stopped coming on. The wall outlet checks out fine. Is there a re-set on the unit? What else can I check?
Hello, if the unit is receiving power check the capacitor, this is a round or oval can located inside the control panel of the Ac, it controls the fan and compressor operation.
May 23, 2012 | Kenmore Heating & Cooling
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
Jul 23, 2011 | Canon MP560 All-In-One InkJet Printer
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Thomson DTI2300 set top box stopped working
If there are no lights and no sound, then you've lost power.
I expect you've checked the fuse? If not go ahead!
Assuming that the fuse is ok, the next step is to check the power board in the unit. The unit pulls apart by un-doing 2 screws; 1 on the bottom and 1 on the top centre of the rear plate. The innards pull out, but you must pull the top panel away from the second screw I mentioned as you pull it out.
Inside the bow you'll find the power board (where the power lead goes to). You're looking for bulging or leaking capacitors; this is a comman failure on these units. They are pennies to buy and easy to replace if you can wield a soldering iron. If you have a handy friend he/she will find it easy.
Jan 13, 2010 | Televison & Video
Maytag Dishwasher MDBH965AW will not power.
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replace
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Kenmore 73189 Air Conditioner Logo
125 people viewed this question
Top Kenmore Heating & Cooling Experts
John Tripp
John Tripp
Bill Long
jdthefixer
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
