Question about Dell 3100cn Laser Printer
Replace Toner message with new cartridge.
I had used some 3rd party toner from Pro-Inkjet.com which was supposed to be compatible with the 3100cn. It worked for 1000 pages and then said I needed to replace it (It was supposed to last for approximately 4000). When I took out the toner cartridge there was toner all over it. I cleaned it up as best I could and put a new official Dell Black toner cartridge in. Now whenever I power up it goes through its calibration procedure and then tells me to replace the black toner immediately. When I take out the Dell toner cartridge there is toner all over it as well. When I look at the "transfer roller?" it doesn't look like it is attracting the toner like it should. All the other color's rollers are densely coated while the black one has a little toner on it but the metal is clearly visible. I don't know if this is related but we have had "ghosting" problems with this printer since we got it. They replaced just about everything under warranty and it never went away completely. We have been printing with "covers 2" setting and "Paper 2" on the main paper tray which seemed to minimize the problem. The problem did however reappear just before the black toner failed.
  • 2 more comments
  • kevcbacon Oct 31, 2007
    Since we were out from under warranty on the Dell it wasn't worth fixing. A new comparable Dell Laser is much more expensive than what we originally paid for the 3100 so we decided to replace it with an HP k4500dtn business inkjet. HP was offering a $40 rebate if you sent in your old printers. So we got rid of the Dell with free shipping to HP and got a $40 check! The new HP is great as it is network ready and includes duplexing. I believe the ink costs are going to be less than our toner costs for the Dell. The ink jet produces great quality printouts comparable to the Dell. I have learned that printers are disposable and now look primarily at ink/toner costs as a major consideration when purchasing.
  • Blink117 Nov 24, 2007
    DELL 3100cn Laser Printer replaced black toner with dell cartridge. When in Printer console it starts to Calibrat and show up as 100% full but at the end of Calibrating it comes up as 0% replace black toner(k).....
    please help
    Blink117
  • thirstycat Feb 25, 2008
    Hi I have the exact same problem, a compatible black cartridge dumped all its toner inside the drum and machine and since cleaning it out as best as possible the black toner wont stick properly all the way across the magnetic roller above the cartridge!!
    Did anyone offer a solution to this or is it crippled? . Thanks
  • Anonymous Apr 22, 2008
    Same problem as others. Used 3rd party toner - worked OK for a while but now it just dumps black toner all over the inside of the machine until the cartrige is empty.
Ok, I got mine working again. Turns out there was about 2 cups of that crappy 3rd party toner all gummed up inside the mixing chamber just behind the metal roller. It was so jammed full of bad toner that the new dell toner couldn't even make it through to the roller. If you are feeling ambitious (and your printer is broken anyway) here is how I got mine working.
  1. Turn off printer.
  2. Pull the toner and drum out of the printer and rotate the carousel by hand until the black toner holder is at the top.
  3. Look on the right side of the carousel where the toner cartridge locks in. There is a white clip. Get a good flashlight and carefully examine how the clip works before you start prying on it. Gently pull back the small locking tab and rotate the clip towards you and remove it.
  4. Look on the other side, opposite where the white clip was. There is a small metal bracket held with a screw. Remove the screw and the bracket.
  5. Now you can carefully lift the *entire black toner housing, roller and gearbox* of off the carousel. You may have to rotate the carousel slightly to maneuver it out.
  6. Set the housing on a clean surface and remove the two screws that hold the scraper blade over the roller.
  7. Dump out ALL the bad toner inside and clean off the roller with alcohol.
  8. Dispose of bad toner and reassemble printer in the reverse order.
When reinstalling the blade you will need to set the gap between the blade and the roller so that a smooth, even layer of toner is spread across the roller as it turns. Too big a gap and your prints will be dark and smudgy. Too small and your prints will be light. I checked my other colors with a feeler gauge, they were all set to 0.018" from the factory. You can eyeball it if you have to but using a feeler gauge works a lot better.
Final step is to install a new Dell toner cartage and allow the printer to calibrate. With any luck your will be fully functioning again.
Posted on Apr 25, 2008
Posted on Oct 31, 2007
6ya staff
SOURCE:
How to replace Konica Minolta Page pro 1580 mf toner. please tell us
is the toner 3rd party or OEM. Replace with OEM cartridge. Well the toner is not the drum you bought a drum it needs toner. ????
go this site for operator manual
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 18, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta page pro 1580 mf toner low message.how to reset?
Replace toner cartridge or did you fill it your self, if there is a chip on the cartridge and you refill your self then the old cartridge is still old. Are you using 3rd party or OEM? replace with oem
Aug 02, 2015 | Konica Minolta PagePro Office Equipment &...
The secretary ordered 3rd party toner cartridges for a Xerox Phaser 6130. After replacing the black cartridge the "invalid cartridge" message comes up. Is there a way that we can use the 3rd...
If you get the "invalid cartridge" message, try completely turning off and unplugging the unit. Then remove the cartridge, close the door and after at least 30 seconds, restart the unit. Then reinstall the cartridge. This worked for me!
Sep 26, 2011 | Xerox Phaser 6130 Laser Printer
HP Color Laserjet Cp2025n Printer - driver says it's out of toner and won't print. No true. I put in new toner cartridge last week. How do I get it toreceognize the new toner?
Did you purchase a new OEM HP toner or a refilled or remanufactured toner. It is possible that the chip is bad on the cartridge in which case if it is a true HP cartridge have them replace it. If you purchased 3rd party go after the vendor to replace it.
Jun 28, 2011 | HP Laserjet Cp2025n Printer
I AM CHANGING THE BLACK TONER CARTRIDGE ON A DELL 3100CN WITH THE ORIGINAL DELL TONER CARTRIDGE AND I GET AN "ID ERROR" MESSAGE
Either the "toner cartridge sensor" N4445 isn't reading the chip in the toner,
or an MCU board P5281 or EEPROM is defective
-Whit :)
Jul 30, 2009 | Dell 3100cn Laser Printer
Replaced toner with 3rd party toner and get error mewssage
most manufacturers these days have incorporated a chip on the replacement consumables to determine if it is a genuine xxx corporation cartridge...using 3rd party voids your warranty,resetting may not be possible under these conditions. check with manufacturer that sold replacement, I'm sure they have seen it before
Jul 24, 2009 | Brother MFC-7340 All-In-One Laser Printer
Cartridge is not compatible
HP has some of their printers stop working if you do not use an "Authentic HP Catridge". This is not necessary and it is an option that can be disabled in the printer config menu. Then you can use refurbished and 3rd party toner as well.
Dec 08, 2008 | HP PSC 1210 All-In-One InkJet Printer
Dell 3100cn-smudge
The print toner cartridge has a small trap door that opens to let the toner adhere to the paper. Remove the toner cartridge and locate this moveable panel on it. This roller is VERY sensitive, and can scratch VERY easy. Use a soft LINT FREE cloth to GENTLY wipe the colored roller if you see any toner build up. If that does not clear up the problem you will need to replace your Fuser Unit which will need to be ordered from Dell or a 3rd party supplier. Its a pretty easy process, and instructions usually come with the fusers. If you have a printer warranty they will fix it for you. Thanks! //CowboysfanZ
Apr 24, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
894 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
