Question about HP OfficeJet 7110 All-In-One Thermal Printer
Hp Officejet 7110 Not Printing From Computer
I replaced the Black Ink Cartridge Like I have Done Before, however this time a message states: "Supply Expired. Printing Stopped. Replace Black Ink Cartridge. Press Enter to Continue." I have done this and still get the same message. I called Hp Tech Support only to discover that my Warranty in no longer in effect and they can solve the problem if I pay them to extend my Warranty. "Black" mail! Help! There is an easy solution to this and perhaps you have the answer. I paid the Premium price for your service. Fletch
  • Anonymous Jan 01, 2008
    My HP officejet 7110 told me i was out of black ink. I repalced with a black cartridge purchased in a two pack. The printer said the catridge was expired and will not let me print although the catridege was new and full of ink. This really bothers me as I am wasting $ 28- $32 dollars. Can u override the equiptment? I tries changing settings but the manual said thios does not override an expird cartridge. Please help. Thanks
  • Anonymous Mar 15, 2008
    I have replaced the colour ink when a message appeared saying it has expired, but the message still says supply expired for the new cartrage
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Posted on Jan 13, 2008
    Scholar:
  • 84 Answers
You seem to be using an expired ink cartridge. Check the date on the cartridge. You see this printhead works in conjuntion with the cartridges and identifies the expiration date of the cartridge leaving you with an error message. If you recently purchased the cartridge I would take it back and make sure you check the date. Ir would have to be over 1 year expired. If that is not the case your printer could be malfuctioning giving error messages. If that is the case you should reset your printer to factory setting. Another could be that the encoder strip may have ink residue on it or may be damaged. Hope this helps
Posted on Sep 08, 2007
    Problem Solver:
  • 18 Answers
Well there are a few reasons for this error message 1) if this is a new cartridge try removing it and reloading it. Make sure that you have removed both pieces of tape from the print cartridge. 2) You have a bad print head (this happens a lot) and 3) you have a bad cartridge and the chip needs to be rest or replaced. Most of the time I see this kind of error it is because the cartridge is not seated right, or because the print heads are bad.
SOURCE:
Replaced ink cartridge 56 and black print text is
Remove the cartridge and use a damp paper towel, wipe the bottom of the cartridge several times. Each time you wipe you should be getting black streaks on the paper towel. After manually cleaning the cartridge nozzles you will need to use a new tower and wipe the contacts on the back of the cartridge. When this is done reinstall it and run a cleaning and then an alignment procedure from the printer software. You should be printing good again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Printing off computer
Most likely your new cartridge has a damaged head. The tiny bit of electronics could have a fault, and therefore not be read properly by the printer. Try taking the cartridge out and cleaning the head with rubbing alcohol - both on the cartridge and the printer - then put it back in. If that doesn't work, try a different cartridge.
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
I have inserted a new color cartridge to an HP officejet 7110 and the message I now get is replace color cartridge as it is out of date. This stops all printing! Can i by pass this?
On this series you cannot bypass for black and white printing. You will have to replace the colour cartridge, but be wared once you've replaced both if your print heads are also expired their warning will come up next and they cost about $120-$150 per set.
If they're still ok you will be back in business, if the message comes up next stating one of your print heads is expired, buy a full set as the messages only come up after the previous is cleared and they all tend to go on the same day.
Hope this helps.
Chris
May 05, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Trouble printing some colors.
Have you tried performing a head cleaning? Usually running the cleaning process will clear it right up. After cleaning run an alignment to make sure the heads are straight.
You can find the utility in the print driver properties and look for maintanence tab.
Hope this helps
TankMurdock
Apr 24, 2009 | HP OfficeJet 7110 All-In-One Thermal...
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Hp printer 7110
hi,
Try to remove the black ink cartridge. From there, you can check the expiry date of the Ink cartridge. If its already expired, then you need to use another black ink cartridge that is not yet expired.
Thank you so much.
adonscott
Jun 18, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Supply Expired!
Reset the printer to the factory default setting that should resolve the issue, you can provide me the make and the model so i can give you the instructions how to set the printer to default factory settings.
May 23, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Supply expired
So many models. Does this model have printheads under the ink carts? If so, remove the print head and clean the jets with a damp Bounty paper towel. Fold the towel up a few times and blot the head into it a few times to clean out the dries ink.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 09, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 7110 All-In-One Thermal Printer Logo
1,802 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
