Philips 50PFP5332D 50 in. Plasma Television Logo
Anonymous Posted on Sep 07, 2007
Shutdown; red LED blinks 4x
Turn on the unit and the relay clicks with a solid green light then the relay clicks again and the red LED blinks in intervals of 4x. The screen never lights up. Is there an error code that coincides with the 4x blinking? I am a bench tech in need of some guidance/help/assistance. Philips MODEL 42PF5321D/37 thank you, carl
  • 15 more comments
  • drpanditji Nov 04, 2007
    similar problem on Sony PFM 42v1N
  • cpipher Nov 07, 2007
    Norcent PM-4201 plasma the red LED blinks 4x and no picture. Where is the backlight located?
  • junior001 Nov 17, 2007
    I tun my tv on and a green light turns on then it automatically goes to stand by can you please help
    Thanks,
    Jr
  • huaqx Nov 29, 2007
    Yesterday I turn on Sony Bravia KDL-46 in HDTV LCD TV gave flash with yellow-color , then no picture/no sound. Turn on again, alway show one second picture (little dark) with sound, then again no picture/no sound. Red LED keeps blinks 4 times. Green LED off.
    I bought it only 14 months. Please advice me.
    Q. Hua in Cleveland (E-mail: [email protected])
  • Aussie in NZ Dec 14, 2007
    I have a Fujitsu Plasma screen and tonight my screen wont light up and the red light is flashing. I turn the power off and then replug the electrical power plug in, there is a flash of green and then the red light starts flashing again.
  • rtowareagle Dec 17, 2007
    When I plug my tv in to the outlet I hear 2 clicks and then a solid red light appears. When I try to turn th tv unit on I hear 2 more red clicks and the tv will no turn on. What do you think the problem is?
  • Anonymous Dec 25, 2007
    this is a plasma and has no back light
  • Anonymous Dec 26, 2007
    same
  • Anonymous Jan 06, 2008
    When I try to turn on my tv it tries to turn on and its power light turns green. Then it goes red flashed 4 times and won't turn on. Any ideas
  • epba Jan 07, 2008
    My t v was working fine and then one day when I turned it on the screen was black. It is like it is dead.
  • fix07 Jan 20, 2008
    i try to turn it on and it goes green then shuts off and red light blinks 4x
  • lavz69 Feb 17, 2008
    same here just happen 3days ago I need help...
  • sanamia Jul 07, 2008
  • papulito Aug 14, 2008
    I HAVE THE SAME PROBLEM. the tv shut down and the image disapear. my technical tv told me that it was the inversor card that comes in pairs, one right and one left. is this correct? the problem is because this card is out or damage? please inform me.
  • Steve Decker Oct 04, 2008
    Shutdown; red LED blinks 6x
  • tmccrayt5 Mar 26, 2009
    I have the same problem. Looking at the circuit boards when the last relay click and the red LED starts flashing, a small board in the top left corner has a green light thats blinking continuously. What does that indicate.
  • MYOPINIONS20 May 25, 2009
    I HAVE HAD MY PLASMA FOR 2 YEARS. I CANT GET A PICTURE NO SOUND NO LIGHTS AT ALL. SEEMS LIKE IT IS NOT GETTING ANY POWER.
A
Anonymous
My fujitsu is only playing in black and white how do i sort this
A
Anonymous
I have the same problem with my tube Philips TV. If I unplug it for a while, then plug it back in, it will start up okay, but then the problem will recur. I was told by the Philips help people that if you unplug it for 10-15 min, plug it back in, and immediately press and hold the power button on the TV for 10 sec, it will "reset." My experience with this is that it is only a temporary fix.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 05, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
16770
Points
Ok guys i have the same problem. mine just shut down and wont turn on. plus the red LED flashes. I sent mine to the shop and they told me the Y SUSTAIN BOARD PCB needs to be replace. This shop is a toshiba registered shop so im assuming they are reliable. Now the problem is toshiba doesnt make the replacement parts anymore. So the shop called me and told me they cant fix it that i have to call toshiba myself and make some sort of bargaining deal. unfortunately I didnt buy the extended warranty that suck real bad. regardless the tv is only 2 years old. As far as i know toshiba should have replacement parts for atleast 7 years and this is by law. So I guess if they have more complaint about this dilemma for sure its a recall. more complaints the better. so guys start calling
Anonymous
Level 2:
Scholar:
  • Expert 53 Answers
  • Posted on Sep 08, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
53
Questions
0
Helped
18440
Points
104
The most likely reason for the no picture might be the back light is gone and needs to be replaced, now as for the LED light blinking on different intervals is because its diagnosing it self unfortunately the user manual does not have any information on this part only by contacting the Phillips customer support you might get a better idea, but check your back light first it may just be that. Also try to check your Manufacturer warranty repair.
Anonymous
Level 2:
Scholar:
  • Expert 72 Answers
  • Posted on May 01, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
72
Questions
0
Helped
71609
Points
123
The Error 4 is refering to a I2C4 communication error between SSB (small signal board), and the Logic board ( located underneath the SSB (under the bracket). Very high probability the SSB is bad. current replacement SSB 12nc is 313926809052
1helpful
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
I'm not getting any internet connection from my router (neither wireless or ethernet). The "Power" light is a solid green. The "Receive" light is blinking green. The...
only IPS can sure that. if model reset fails
no kidding call them. like millions do per day worldwide.
the ONLINE led must glow, the manual is clear about LED
and connected is no it, online is first. on modems and in this case the modem side of router./modem.
3347w = wireless
LED DSL goes green solid but blinks as DSK trains and conn.
and
LED interenet solid green connnected. blinks for data and red = fail.
page 205 in 3000 series manual
google it read it..
online means internet, and fails for you
and means call the ISP any time the internet led goes dead or red
it is that simple. do it.
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
4helpful
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
3answers
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
2answers
50" philips won't power on. get the 4x red blink led light
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
2answers
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
