FixYa.com
Tags:
Haier BC112G Wine Cooler
Fridge
posted by ttex on Sep 07, 2007
Fridge not running
well
Comment by ttex, posted on Sep 07, 2007
Sorry, I was wondering why my fridge will not auto shut off? Keeps running around the clock.
What parts should I check to replace?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 04, 2008
Not Rated (0)
DiYerTech
Rank:Master Master
Rating: 92%, 12 votes
To Ttex:
I received this cooler as a gift and it is probably working fine; as the units' two fans in the back run do run all the time (common complaint and the unit is not Energy Star certified). Only the electronic cooler portion turns on & off periodically when the temperature inside rises 2 deg. above your setpoints (you will hear a subtle click when it "kicks-in").
By the way, if the room temperature is 85 to 95 degrees, the cooler has a hard time maintaining 54 deg & 55 deg settings (when to 59 & 60 deg respectively.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 08, 2007
Not Rated (0)
fishers
Rank:Wiz Wiz
Rating: 84%, 80 votes
Not sure of what type of fridge you are refering to.. However you can try a few obvious things.
Try turning the thermostat to a lower number (warmer setting) to see if that makes a difference.
If you have an ice build up starting to form on the fridge plate or only a partially cold plate then you could have either a loss of refrigerant or compressor fault.
Is the compressor noisey in comparisson to its normal noise.
Is there heat being produced all over the condenser (black finned section on back of cabinet or underneath cabinet)..If not possible gas leak.
Hope this is of some help.
Can you Help with these Refrigerators problems?
Haier BC112G does not cool -...
Electrical works (Light and... Answer This...
does anyone know how to lower...
I keep both white wine and beer... Answer This...
Door will not shut properly
Door seal has a gap of apprx... Answer This...
Haier Wine cooler
Our 32 bottle Haier wine cooler... Answer This...
Durabrand Wine Cooler
Need a manual for model... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
