1. locate where you want the switch (such as inside the RV or on a stake that can be placed near the shower enclosure)
2. If the pump runs on 120 volts make sure the location of the switch is not going to get wet or it may be your last shower ever. If the pump is 120 volts (house current) it may be safer to run an extension cord to the pump and just plug the pump in from the inside of the RV when you take a shower.
3. If the bilge pump is 12 volts just get an on/off toggle and run wires from the toggle switch to the battery and then the red (positive) wire on the pump.
I have been unable to locate the toggle switch in a SaniServ Operational Manual located HERE , I suggest you call and ask Saniserv what this toggle switch is for 800-733-8073
there should be a wire that connects to your e-brake swith, located near the e-brake all you have to do is connect this wire straight to earth and you should be able watch movies all the time,
buy a toggle switch
run a wire from the red wire located at the back of deck
to the deck and toggle switch (power to power on toggle switch)
do the same with the ground wire (black) (ground to ground on toggle switch) (make sure to follow logos on toggle switch)
finally install e brake wire to center pin on toggle switch
now you can watch make sure toggle switch is on
if this didn't work switch the e brake wire and black wire on toggle switch
good luck hope i helped
