Question about Refrigerators
Beko fridge freezer not working... not cooling
Hi my fridge does not seem to be cooling to a cold temperature... it is on from the mains, not leaking, not smelling... not working even. would it need replacing or can it be fixed?
  • 5 more comments
  • Anonymous Jun 12, 2008
    not working its making a bubbling sound from behind i was told to turn it off for 24 hrs and leave doors open ! ive done that still not working and still bubbling
  • shirley_hari Jul 23, 2008
    beko fridge freezer, the freezer is not freezing but fridge is ok. Does the fan inside the freezer continually run or is it intermittent. mine is intermittent how do i fix it
  • amanda quin Sep 08, 2008
    i have just bought a beko fridge frezzer opend it an let it standing 4 about 12 hrs, turned it on an the light wrks in the fridge an the fan wrks in the frezzer but it is not frezzing up the both compartments are warm!!
    the only noise thats coming from it is from the fan
    can someone tell me what the problem is an how costly it will be to fix, thanx
  • Anonymous Feb 28, 2009
    I had my Beko fridge for 1 year and 2 months same thing its all switched on but food has defrosted a bubbling like noise from the back only a years warranty payed £300 for this what a waste I have scrapped it .....
  • Anonymous Apr 28, 2009
    Bubbling at the back and everything defrosted, luckily saved the frozen food in time. think it's a bit unreasonable for a fridge freezer to last only 2years 3 months. and I didn't take out the 3 year extended warranty. A fridge should last longer than this! I will be persuing this with beko because as I said it is unreasonable!
  • crackingup May 16, 2009
    BEKO fridge freezer just over 12 months old noticed not cooling or freezing, the light still works. Only noise is a bubbling sound from the back. I will be getting in touch with BEKO as i think this product should last a bit longer than a few months
  • Anonymous May 22, 2009
    went to fridge, Beko like the others, CDA653F cost £349, about 18 months old now, freezer goods all defrosted? Has been 24hrs now and still nothing happening, even noticed fridge part seems to not be working too? Have turned it off and back on, motors running, light in fridge works and fan in freezer not moving, like someone else though, am not sure if this should be continuous or not anyways?
    Got no idea what to do about it? Freezer and fridge pretty well stocked too so not happy at all!!!
  • 38 Answers
Yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Posted on Sep 08, 2007
My beko fridge/freezer is working but not cold in fridge and not frozen in freezer what can i do?
Posted on Apr 30, 2011
If your freezer is still working but you fridge is not cooling try looking at the vents in the freezer if they are frozen up this will stop the fridge getting cool air , defrost the whole unit and see what happens its worth a try before you call out a repair man ,by the wat i have a beko american style fridge freezer,and had no faults showing on my digital display.
Posted on May 26, 2010
Beko cda539f fan not working
Posted on Feb 27, 2011
Red exclamation mark lighting mean
Posted on Jul 28, 2011
Hellow Engineers can anyone help me.when i turn on My peko fridge holle socket system goes off, the frigde is dry and we didn't used about months
Thank you
Posted on Oct 17, 2012
  • Aden Jaama Oct 17, 2012
    Beko fridge freezer shotdown electric system
    Thank you
Does anyone know waht does it mean if a red exclamation sign appears on the display????
thank you
Posted on Aug 05, 2008
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
The refrigerator is not cooling enough. Even though I turn the dial up to the maximum 7, the temperature will not go below 50 degrees. I need to maintain a temperature below 47 degrees.
There could be two reasons for this
The thermostat is not working properly - replace the thermostat
There is a small refrigerant leak and the fridge cannot get cold enough - you will need a technician to find the leak and regas the fridge
Mar 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is not cold, freezer is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 26, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
THE MAIN FRIDGE IS NOT WORKING, THE TEMPERATURE SEEMS TO BE VERY WARM. THE LIGHT INSIDE THE FRIDGE IS WORKING OK AND SO IS THE SOUNDER WHEN THE DOOR IS LEFT OPEN.
Listen for the fan that is in the freezer section. The fridge part relies on the freezer fan to get it's cold air. Only the freezer section gets cold...the fan in the freezer blows cold air through ducting to the fridge to get it cool. Either the fan is bad or the air ducting to the fridge is restricted by ice. If the airway is restricted by ice then your defrost timer is bad. Good luck.
barneyluc
Oct 10, 2008 | Refrigerators
Bottom of my fridge is leaking and has a funny smell, all fans are running but fridge is not getting cold enough even the freezer, around the freezer feel really warm?
Does it smell like ammonia. Turn the unit off if it does. Look for yellow powder on the back this would be another sign the cooling unit has leaked. The only solution is to replace the cooling coil.
Sep 06, 2008 | Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
12,785 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
