Question about Canon BubbleJet i560 InkJet Printer
Prints blank pages only (2nd question)
I cleaned 20 times--still no print--If one color is blocked does it stop the other colors from printing also?--do I need a new print head?--thanks
    Scholar:
  • 84 Answers
You will probably have to replace the print head. But you can try this first. Take out all the cartridges. Using distilled water, a print head cleaning solution, or alcohol. Take a Q-tip dip into solution and saturate the nozzle area when the in flows through for each section. Slide a sheet of or paper towel underneath the printhead to soak up fluid that comes through. Take a paper towel fold it making a strip. Run hot tap water on the towel..not too much. Then place the cartridges on the towel. The heat will pull the ink down. Let it sit until you see ink on the towel from each cartride round 5 minutes or so. Take a dry cutip and clean out the ink residue inside the print head sections. Then reinsert the cartridges. Run the clean utility from your software a few times until the print is good. If this does not work replace your print head. Hope this helps.
Posted on Sep 08, 2007
My Printer started randomly printing blank pages when looking for color. Prints color every now and again, but generally blank. Prints fine when I set to Black/white only.
It is more likely that the settings need to be changed on a print job to job basis in the program you are generating the content from. There are usually defaults set in the software and you need to check these settings every time you print.
Mar 11, 2015 | Canon imageCLASS MF8170C All-In-One Laser...
Yelllow color is not printing
check yellow cartridge to see if toner seal tab has been pulled out
Aug 31, 2014 | HP LaserJet 2840 All-In-One Printer
Mp960 color prints ok but black and white not printing
When was the last time you printed in color? New ink printers are built so with a "use it or lose it" theme. The print heads are now built into the machines and are not generally replaceable. Yours luckily is, but I don't know how easily. The link below is to the replacement which costs $130 + shipping. Sometimes it can be just as worth it to buy a new machine, in this case I would probably prefer to repair the damaged machine as the new printer cartridges cost more and have less ink.
Feb 16, 2010 | Canon PIXMA MP960 Printer
Prints only blank pages
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 06, 2010 | Brother HL-2040 Laser Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Mp370 nnot printing color even after changing ink tank
take out both ink cartridges, lift up head clip and take out printhead block
stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
do a clean cycle
Nov 21, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
MISSING COLOR IN MY PRINTS
try a test page first and see what that does
Aug 08, 2008 | Epson Stylus C46 InkJet Printer
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
Canon BubbleJet i560 InkJet Printer Logo
104 people viewed this question
Clive
Clive
old marine
old marine
