Question about LG 52SX4D 52" HDTV
Light Engine? (The white light will roll for a couple minutes then turn red indicating i need to replace my bulb but it never gave anykind of warning. The manual mentions a orange light should appear when bulb is about done, but that never happened. I'm curious if I should replace the bulb or if it is something else. I've had the TV for about 18 months) I had this same problem, replaced the bulba dn still nothing. Then they told me to replace the light engine which acording to them is another $800.00. Are there any other possibilities?
  • 1 more comment
  • tony347 Sep 07, 2007
    its a breand new lamp and balast...detecting no fault with fan operation...any other ideas?
    if light engine, how much $$ am I looking at?
    i'm already $500 into this, another $800-$1000 and I can easily buy a brand new TV!!!
    you wanna buy this one for parts? :)
  • tony347 Sep 08, 2007
    Like I said, I already bought a new lamp and balast...spent $500...and still nothing...since then, I bought another 50", and's a Samsung! It has been great (and I bought the extended 5 year warranty) This one only cost $1400.00. The reason I want to fix the LG is that I bought it 3 years ago when the technology was new and I paid $2700.00 for it. With the $500 already invested, I feel like I should give it another shot! If you think it's going to be another $900.00, then I'm not interested...I will take it to the dump!!! unless you want has a brand new lamp and balast!!!!
Tony! I had the same problem and here is the story I checked the bulb and it was cool so I called a guy since checking the balast is dangerous and you need the parts. The problem with this tv is that there is no good method for checking a problem they just plug parts in untill it works that being said he had my tv for a month. (due to having to order more parts. it could be the color wheel or different boards. for some reason my color wheel and two boards were shot so it cost me 900 bucks. I have a good surge protector so I ruled that out. From now on I will buy Samsung. after that it worked; however, shortly there after my lamp went out. I made a loud popping sound and I replaced it myself. A good place to buy a new lamp is the part number is GTL-OS-69386. its after market however it seems better than what I had.
Posted on Sep 08, 2007
  • 375 Answers
Try removing the lamp and inspecting it if it's not shattered inside ,chances are it's ok and you might have another problem ,possible balast fault,that drives the lamp assy. look for fan operation also.
Posted on Sep 07, 2007
  • g w Sep 07, 2007
    check for safety switches first and fan operation,an engine could run form $850.-1000/i would invest in a service call with an est from a tech.
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Jeep 95 warning lights ?
The gentleman above gave you the correct starting point. There are red and amber lights. Amber usually indicates a problem with the engine electronics or emissions system. Red lights are related to charging or alternator problems and engine overheating. If a light comes on you need to check the related system before you wind up disabled on the side of the highway.
Feb 04, 2009 | 2003 Jeep Grand Cherokee
Red light on no picture will work fine after several minutes
There is a list of things you need to check, but offhand I'd say that the 5 volt line is low and probably right on the"edge", which is why it works sometimes and not others take a look at this list:
Cause #1
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for
12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check
for an open F9A09 on the Power PCB, if it is open replace F9A09 part #
283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out)
Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if
low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the
Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three
times and then the unit shuts down with a red lamp LED (lamp error). Replace the
Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch
to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light
Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low)
after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB
(ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-
volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light
I would say try #3 first, the two caps on the pwer supply board. A couple of warnings: as always, unplug the unit before servicing. The power supply is located on the left side, if you behind the unit. It is in a shielded box and the shield has VERY SHARP EDGES so use care when you try to open it or you will slice your fingers.
Please be sure to rate this solution. Thanks!
Nov 08, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Flashing Green Power on light not picture
Last Saturday evening, I experienced the exact same behavior on my Panasonic PT-52LCX65; it shut itself off without warning. I turned it back on, and it shut itself back off after about a minute, and the red "Lamp" LED on the TV began blinking.
I never got any warning message that the lamp was about to go out, but I've just replaced the lamp and now the TV is working just fine. We had to mail-order the new lamp, because neither H. H. Gregg (where I bought the TV on "Black Friday" 3 years ago), Fry's Electronics, nor Best Buy carries the part locally.
My wife found the new bulb WITH its holding apparatus for something like $120 online, roughly half what other sites were charging. We paid roughly $55 for UPS Next Day Air. The first bulb that was sent arrived broken (some UPS rep apparently thought "Fragile" meant "Shake and Drop"), but the company we ordered from cheerfully rushed us another one, and the second one was in much better shape. (Panasonic doesn't pack these replacement bulbs very well; there's a heavy bulb with a lot of air around it that Panasonic doesn't fill.)
More details available if anyone wants 'em. Hope this helps. -- ChuckE
Nov 03, 2008 | Panasonic PT-52LCX65 44" HDTV
How to replace headlight on a 2003 Chevy Tracker
There are two black plastic clips behind the the air filter, remove them and release the whole assembly to access the lights.
If you still get in troubles, have it replaced at a petrol station, they will help you in fitting the bulb, and it won't be expensive.
Here follows
2003 Chevrolet Tracker Light Bulb Size Chart
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 1157A
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 921
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 168 Or 921
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 74
Step/Courtesy Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 168
Instrument-General Light Bulb Size: 158 or 74
Check Engine Indicator Light Bulb Size: 74
Hi-Beam Indicator Light Bulb Size: 74
Seat Belt Indicator Light Bulb Size: 74
Brake Warning Light Bulb Size: 74
Automatic Transmission Indicator Light Bulb Size: 74
Directional Signal Indicator Light Bulb Size: 74
Oct 02, 2008 | 2003 Chevrolet Tracker
Sony projection tv does not turn on
There are a lot of sites that sell bulbs for those. Use a search engine and the model with the word bulb. Be aware that it may be the ballast though.
Oct 12, 2017 | Televison & Video
Lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
May 14, 2008 | LG 52SX4D 52" HDTV
Red blinking light
Jan 04, 2008 | LG RU-60SZ30 60" Rear Projection...
Won't piwer on
Tried to turn it on? Sounds like you need to replace the lamp. However, I got an additional week out of my unit. Although poorly dimmed and the red Lamp light blinked constantly for that one week, at least it gave me enough warning to seek out a replacement. But so long as you're not mistaking the Power/Standby or Timer light for the Lamp light then I would have to agree with you. Includes shipping to the United States and no sales tax outside of California.
Aug 16, 2007 | Sony XL-2100U Projector Lamp for...
TV not turning on
its probably pretty close to time at 18 months and they often give no warning, I believe the orange light on an LG is just the lamp timer which really just counts hours. Pull the lamp out and look at it they often physically break inside and it is obvious
Apr 27, 2007 | LG 52SX4D 52" HDTV
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
148 people viewed this question
Computer Repairing
Computer Repairing
