Question about Motorola Mobility RAZR V3
White screen power down, "end-power" key not working; sticky
V3m powers on on battery install, sets up then power down to whtie screen, if not in use.power button not working deleted video except one called bronze wont go away. Phone was puchased in Dec'06, problems started in Feb/Mar, phone stored away till July ( sent in to Moto, says water damage, Not).Attempted to use in July, caught an automatic sprint upgrade then problems started bigin with small LED staing on, Camera stop working, then to the power down issue. Dont know enough about which flashing programs would work best for me since it seems V3M has limited options. thanks.
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service center and have them reflash the phone.
Posted on Feb 18, 2008
How to reset sanzo zio phone
WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
8. Allow the phone to completely reboot. This may take a few moments.
9. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
Dec 02, 2011 | Sanyo Cell Phones
Tip
How to reset Kyocera Zio m6000
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
To reset Kyocera Zio try the following:
1. Remove battery and put it back after two minutes
2. Press and hold down the home button key while turning on the phone.
3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
If it does not work, try:
Hard reset 2.
a)
b)
Procedure, cont.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If still no luck, call Kyocera directlyand report the problem.
on Sep 03, 2010 | Cell Phones
How to reset cricket zio
a)
b)
Procedure, cont.
NOTE: If you receive a self-test screen or blue screen, the hard reset was done incorrectly. Please try again, from step 1.
Dec 02, 2011 | Cell Phones
My kyocera sanyo cricket phone screen is locked how to unlock it
Hard Reset.
1. Turn off the phone
Phone is completely reset as if it came out of the box. You'll need to *228 and reload ALL of your data.
or WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
a)
b)
Procedure,
Sep 12, 2011 | Kyocera Zio M6000 Cricket
I need to hard reset my sonyo zio
Zio Hard Reset From Cricket corporate
a)
b)
Procedure, cont.
Nov 17, 2010 | Google Android
MY NOKIA 6111 DISPLAY IS WHITE
white screen nokia 6111 problem
Dec 24, 2009 | Nokia 6111 Cellular Phone
Razr v3m text problem
Have you done any modding to the phone and is it still under warranty?
Also who is it through? Provider?
Mar 19, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Razr V3M Power-up/Black Screen
I ended up having to take my phone back to Verizon.  They replaced it with a brand new one because they were unable to find the problem.
Oct 16, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Flashing on and off
well that and unlocking the phone voids your warranty. First try taking your battery out and then holding down the # and * keys while you put the battery back in. If it didn't automatically load to a black screen displaying your software version, power it on while holding down those keys. once you've reached this screen let go of the keys and power it on normally. If that doesn't work reply to this post and I will troubleshoot further.
May 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
