Question about Konica Minolta DiALTA Di200 Copier
Code C0500 I am getting this code C0500 in my Minolta Di200 copy machine. How can I fix this code.I red one solution in this forum which is "C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode. Go to "Counter" Go to "Trouble" Trouble reset If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar. You may need to clear the counter by pressing "clear" and then "end". After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!" but I do not know how to access tech rep service mode. Is there any one who could guide me in this matter. Thanks.
Simulation = UTILIY -----> METER COUNT (on touch screen)->
STOP------> 0-----> 0------> STOP------>0------>1
Posted on Jul 02, 2008
  • 163 Answers
Press meter count,press utility go to error and then ok the reset error or press the micro switch on the master board if not going heater unit fuse or thermistor problem
Posted on Sep 14, 2007
2 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
To access service mode:
Hit the utility/counter button.
Touch meter count.
Type the following on the keypad:
<STOP> <0> <0> <STOP> <0> <1>
Posted on Jan 03, 2008
How to reset the C0500 code on a Di1610 machine
power off the machine, then hold down the stop button and power on. if the code comes back DO NOT RESET the Fuser (HOT PART BACK OF MACHINE) is bad it can catch on fire REPLACE IT.
Jul 02, 2014 | Konica Minolta DiALTA Di200 Copier
IT AUTO CUTS POWER AND GIVES A CODE THAT IS C0500
i have a SF- 2510 sharp copier that is displaying the error code C0500. What does this code mean and how do I fix it?
Feb 23, 2011 | Konica Minolta DiALTA Di200 Copier
Minolta error code c0500
A C0500 code deals with the fuser temp. You maybe able to reset the code, by pressing the trouble rest switch. If it will not clear you will need to look deeper into the fuser unit. I don't know what model you have, so I can not go any further. Good Luck
Nov 24, 2010 | Office Equipment & Supplies
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
I have a problem whith minolta dualta di200,the problem is "error code c0500,can somebody help me?
C0500
The temperature of the Fusing Rollers does not reach
the required level even after the lapse of a given
period of time during a warm-up cycle.
There should be a small opening or hole on the right of the operation panel, use a paper clip to press the button inside. This will reset the machine. If the error code was a glitch or a false code the machine should operate. If the code comes back you will need to have a technician replace the fuser assembly
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
Minolta Dialta Di200 malfunction
1-The C0500 code can be reset following the steps below: find a small
hole on the right side of the control panel. press it using a paper clip
2) When the dot appears on the LCD after reboot, press the number 3 key.
3) The mode will change to the initialization screen.
4) Choose the selection for trouble reset.
5) After reboot the code will be cleared.
good luck
Feb 10, 2010 | Konica Minolta DiALTA Di200 Copier
Error code C0500
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
Jul 21, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
C0500 malfuntion
C0500: Warming-up Failure C0510: Abnormally Low Fusing Temperature C0520: Abnormally High Fusing Temperatu
Dec 28, 2008 | Konica Minolta DiALTA Di200 Copier
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
2,158 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
