Question about Maytag MER5775Q Electric Kitchen Range
I dont know the Maytag model - but is has a CERAN top
The small heating element on the left is not working. How do I open/replace this part? Range came with home when I bought it and no manuals
  • SheilaK Sep 10, 2007
    Hi - I will get the replacement element and then try what you have specified. Thank you very much.
  • 5,911 Answers
There are a few screws located under the front edge of the top. You will need to open the oven door to see them. Remove these screws and the top should lift up. Make sure you unplug the range or turn off the main breaker BEFORE servicing. There are still live voltages present with the range turned off. There are a couple of screws holding the element in place, as well as some wires. Make sure you write down how the wires were connected to assist you in reconnecting them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of on the old element. Last of all, make sure you handle the new element carefully. Care must be used not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. Good luck and I hope this helps.
Posted on Sep 08, 2007
Range works fine, but oven takes forever to heat up. sometimes i will shut it off and back on to see if it will work. what do you suggest
There is a thermostat inside the oven sometimes on the upper left corner. When the element to the probe goes out the oven doesnt know how to heat up anymore. The element is very inexpensive to replace and easy to do. It should have 2-3 small scres holding it in and it can be pulled out for replacement.
Jul 08, 2012 | GE JGSP23 Gas Kitchen Range
Moved range from home to cabin. Now when trying to use oven it won't heat. By turning on one burner on the top the range will heat. If we turn off the burner on the top the oven will continue to heat....
If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Take care.
Sep 04, 2010 | KitchenAid KGST307 Gas Kitchen Range
Baking element replaced but still won't heat
you may have triped half your 220v breaker. (you should have shut it off when reparieng wire or it would have been live and zaped you) Or something in line with the wire that shorted blew out like a fuse in the range.
Nov 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Frigidaire electric range fef326ab bought in oct 2005 heating element sparked while baking and now there is a hole in element, what could have caused this and could it be fixed, or will i have to buy new...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573215
Generic problem for all Kitchen Ranges
Posted by keepcooking on May 05, 2008
Frigidaire electric range fef326ab bought in Oct 2005
heating element sparked while baking and now there is a hole in element, what could have caused this and could it be fixed, or will i have to buy new range?
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
To the best of my knowledge you can replace the heating element with a genuine part from Frigidaire, this happened to me on my water heater and the element just got old and too hot and it just popped and left one to three holes in the element and I just replaced it. I would have it done by an appliance specialist or your local appliance repair person. When ordering the part remember to give the Brand name, Model # and they might ask for the Serial #. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.frigidaire.com/products/products.asp
Contact Us
Customer Contact Center - USA
1-(800) 374-4432 Monday thru Friday 9:00 am to 5:30 pm EST
Canada 1-(800) 265-8352 Monday thru Friday 9:00 am to 5:30 pm EST
Extended Service Agreements 1-(866) 386-5286 Monday thru Friday
8:00 am to 6:00 pm EST
Order Genuine Frigidaire Parts 1-(800) 599-7569
8:30 am to 5:30 pm EST
Mailing address:
Electrolux Home products
P.O. Box 212378
Martinez, GA 309
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
May 05, 2008 | Kitchen Ranges
Surface element not working
if the indicator lites up replace the element the sensor is probably bad you can take a small screwdriver and pry the connectors loose safely btw the sensor is the rod running across the element
Feb 12, 2008 | Kenmore 92420 / 92421 / 92422 / 92424 /...
Looking for the part no.
the part you need is called the upper oven hi limit thermostat any appliance parts store can get it with your model number and any stove wire will do if you cant find it there then try here http://www.pcappliancerepair.com/cgi-bin/promotehome.cgi?affiliate_id=GSMK01ag
Feb 11, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore Range 911.9324890
Replace recepticles for large elements. It is the part that the heating elements go into. And while you are at the appliance store, pickup a new bake element for your oven. Just unscrew element from oven wall and install new one.
Nov 16, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Range element does not work
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 25, 2007 | KitchenAid KERC507 Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
169 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
