Question about Kyocera Oystr KX9 Cellular Phone
Kyocera oyster My phone screen display does not work. The phone comes on and I can make and receive calls, but I can not use the screen. It is black but there's a shadow on the sides showing some light. The phone worked fine one day and I plugged it in as usual at night but in the morning, the screen did not work. My warrantee ended last week (figures) and I just need to know if there's a fix before I buy a new phone. I just don't want to have to find all those phone numbers in my address book again.
  • stephdun Sep 07, 2007
    I tried the light and see no display...Also, the kyocera oystr does not use a SIM card so am SOL. Thanks
  • Yamon Nov 10, 2007
    Exact same problem! my e-mail is; [email protected]. HELP!
My phone also suffers from this problem, it needs a new cable that goes to the screen. about a $5 part at your local radio shack!
Posted on Jan 18, 2008
I had the same problem a few months ago--then I accidentally dropped the phone on a hard wood floor, and when I picked it up, the display worked again.
Posted on Dec 31, 2007
    Scholar:
  • 133 Answers
Shine a bright light on it and see if you can see and resemblance of the display on the screen. If you can see a display, the backlighting on the screen is broken - if you can't see a display, it's likely the screen is broken or the display controller is broken. Backlight would be the cheapest fix, usually. Also, you should be able to transfer your phone numbers over to a new phone by using the same SIM card so long as the phone numbers were stored on the SIM card - the only way to find out is to put it in another phone and check out the address book.
Posted on Sep 07, 2007
  • Ricky Burgin
    Ricky Burgin Sep 07, 2007
    You might want to check eBay for a replacement screen for the unit, you can usually pick them up cheap if you fancy a go at repairing it yourself.
SOURCE:
I call someone, and they answer, and can't hear me, but I can hear them. Then the call disconnects. I know it is my phone, because it happens with whomever I call. I have a Virgin Mobile Kyocera oyster
Given it to a repairer might be risky repairing your phone.
Your kind of phone needs a matured hand to handle it.
It's the mouth piece of the phone that makes people hear you that needs to be changed.
I suggest you take it to the company you bought it from fr safer reasons.take care..
Jan 27, 2010 | Kyocera wild card Cellular Phone
Speaker doesn't work
take you phone to a cell phone tech and they can put a new speaker in it.
if your oysters didn't damage the main board.
Jun 10, 2009 | Nokia 7373 Cellular Phone
Kyocera candid ii will not send/receive calls.
you have to deactivate your call divert service for all
May 19, 2009 | Kyocera Candid KX16 Cellular Phone
Kyocera oyster screen blank
I hope that when you say blank it means partially lit, with a kind of background, but no image.
This solution is not for an abused phone, as it does not seem to be mechanical, or due to a loose connection. It rather seems like a firmware failure. It will not make your phone usable, instead, it will enable you to retrieve your saved numbers. Once these cheap things start failing they become disposable.
Tried removing battery: No cigar. Tried opening it carefully (under 90 degrees) still no solution.
Here's what worked for me. Phone off, either by powering it down of by having removed the battery.
Get a toothpick, and with the phone CLOSED in the off position, pinch the power-on button and let the phone come on closed. It may not work the very first time, but you should be patient. Once it comes on, you can do just about anything with it until you power it down.
**Make sure you have charged your battery prior to this, since will be spending some time retrieving your numbers**
Good Luck!
Aug 28, 2008 | Kyocera Oystr KX9 Cellular Phone
Blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
May 01, 2008 | Kyocera Oystr KX9 Cellular Phone
Display black
Good Luck!
Feb 18, 2008 | Kyocera Oystr KX9 Cellular Phone
Can I change the screen image (wallpaper) on a Kyocera K126C? - if so, how?
Hi!
In answer your question: On the Kyocera K126C cell phone, the wallpaper image cannot be changed. This type of phone is not capable of receiving downloads of different wallpaper images or ringtones. You will just have to deal with the wallpaper picture the phone's display screen comes with as well as the ringtones that are built in to the phone.
Feb 03, 2008 | Cell Phones
Kyocera oyster
This phone cannot recieve picture messages because it's not a camera phone. With this phone company only camera phones can recieve picture messages.
Jan 26, 2008 | Kyocera Oystr KX9 Cellular Phone
Kyocera Oystr KX9 Cellular Phone Logo
535 people viewed this question
Top Kyocera Cell Phones Experts
Jeffrey
Level 1 Expert
Mufaddal  Kurlawala
Mufaddal Kurlawala
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
