Question about Printronix PrintNet Print Server
Printronix P5412 Do not Print
Hi.... The printer does power on test OK The 19-205-100 LAN Interfase flashes 2 green leds during power on test. When Printer get ready, all 3(2 green +1 red) led are OFF. No error condition at all at panel. When en job is sent to print it finds the printer READY but.... nothing happends! Desperate from Caracas, Roberto
Re: Printronix P5412 Do not Print
Culd be a configuration problem on the Print net, maybe the memory size in flash and dram, but the printer recognize the print net??
Posted on Jan 22, 2008
  • 132 Answers
Sounds like this unit has some electrical (minor) damage.
Posted on Sep 19, 2007
0 characters
3 Points
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Print Servers
Communication between PrintServer DP-301U and HP LaserJet 1020
Trying turning your printer off and then back on. It happens sometimes that the print server looses the printer.
Feb 13, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
How to reset Pocket Print server Extended Sys ESI 2833?
Disconnect the power. Press the small test button and keep it pressed, while you reconnect the power AND wait until the green LED is on again.
Dec 05, 2008 | Extended Systems PocketPro Print Server
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Epson stylus C44UX and zps1001 zonet print server
Since it's over a year since we had any response on this, I think we might call it "Solved by Poster".
Jan 13, 2008 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Printronix printer connected to scounix server
culd be a emulation problem or maybe spooler configuration
Oct 31, 2007 | Printronix PrintNet Print Server
Can't print
try unplugging the printer and router and restart them your ip- my be used by other device.
Aug 17, 2007 | D-Link DP 303 (DP-303) Print Server
Datamax E class
Go to Control Panel > Pritners and Faxes. You should be able to see your printer there. You can check and ask it to print a test page.
Jun 05, 2007 | Datamax 1/PK EXTERNAL LAN INTERFACE METO...
ALERT LED light - Blinking Amber - Nothing prints, printer not recognized
The blinking amber light means there is a hardware problem. Got that from Netgear's website because we have a similar problem here. I don't know if it means hardware problem in the print server or in the printer. We put the print server on a UPS Uninterruptible Power Supply and that problem seems to be gone. We are in an old factory and the wiring is not so reliable. Maybe you could try this same fix.
Nov 28, 2006 | NetGear PS101 Mini Print Server Print...
Printronix PrintNet Print Server Logo
130 people viewed this question
Top Printronix Print Servers Experts
old marine
old marine
Are you a Printronix Print Server Expert? Answer questions, earn points and help others
