Question about ViewSonic N3000W 30 in. HD-Ready LCD Television
Removal of base
Is it possible to remove base stand in order to fit wall fittings
  • 2 more comments
  • Anonymous Nov 27, 2007
    i cant remove my tv base so i can mount it on the wall email me back at tedwilliam99@hotmail.com
  • Anonymous Dec 05, 2007
    just want to know how to remove the tv base to put on wallmount
  • fixnow1 Jun 03, 2008
    Who did you get to mount the tv on the wall? Montg., AL
  • Anonymous Mar 21, 2014
    Removal of base stand
    New Friend:
Get the graffiti removal service in Australia from valuable and breakable products. Our team is expert to handle the case without damaging from like plastic, glass. Contact at http://www.officecleaning.irish/graffiti_removal.php
Posted on May 26, 2016
How do you remove the base for wall mounting model 32hlc56?
Posted on Feb 08, 2009
    Scholar:
  • 133 Answers
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Posted on Sep 07, 2007
Replacing jet
When you installed the new jet, did you install a new gasket on the wall fitting or use 100% RTF type silicone?
In order to seal a wall fitting that is cracked an leaking, the replacement must have either the gasket or silicone to seal the wall fitting against the wall of the tub or it will leak when filled with water.
Rod
U S Parts Center
Jan 03, 2014 | Jacuzzi Home
I have a 42 in. Vizio Galleria and need to remove table top stand so I can wall mount. How do I remove base stand?
1. Unplug all of the cables and cords from your GV42L FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
5. Gently remove the stand base
6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
Mar 13, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
How do I remove the base so I can put the TV on the wall
Most TV's have the base fitted with a lock that clicks on the main frame of the LCD TV. So all you need is to keep the LCD on a soft surface like a mattress and check to see the lock linked to the main frame. Push to remove the link locks and remove the base stand.
Jan 12, 2011 | Daewoo DSL26T2WCD 26 in LCD TV
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
Remove stand of bottom of tv
I need to take the stand off my 42" jvc to mount it on the wall. How does it come off
Feb 04, 2010 | Televison & Video
Akai LCD 27 in stand
According to Akai, the base stand for this unit is not available as a replacement part. You may want to try ebay for a replacment stand.
Apr 15, 2008 | Akai LCT3201AD 32 in. LCD Television
Stand
How do I remove the stand?
Apr 13, 2008 | Toshiba Televison & Video
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
ViewSonic N3000W 30 in. HD-Ready LCD Television Logo
1,071 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
