-   Several months ago the "CPU LOW BATT" message came up on our control panel. By pushing the STATUS button the beeping will stop of a few hours then go off again. A couple of days ago I replaced the backup battery located in the security box in but the CPU LOW BATT warning still goes off every few hours. Very upsetting. Does anyone have any info on how to reset this message at the control panel.
Thanks-   bahia92649
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it...
(More)
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it back up the alarm sounds and the code number will not stop it.How do I remedy this?Thanks.
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code...
(More)
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code for the mother, it says invalid or cannot be used. Does it matter if I duplicate digits??? example code: 2311
we have had a gemini security system but have not installed it. Then, the baby in the house pressed...
(More)
we have had a gemini security system but have not installed it. Then, the baby in the house pressed on, but no one had a code. it has been going on repedely.
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I...
(More)
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I can't figure out how to open the control panel. Thanks a lot for the answer, Mike
