FixYa.com
Tags:
Fax Machines
Generic problem for all Fax Machines
Connecting additional telephones
posted by teen 37 on Sep 07, 2007
I have just purchased this fax machine and i have connected an additional phone to the EXT socket on the fax machine. When I receive any calls and answer with the connected phone it does not pick up the call, I have tried taking over the line by pressing ** on the connected phone, this does not work either. I have to then press Stop on the fax machine. Any Ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 07, 2007
Thanks for Trying (70)
sandrew
Rank:Wiz Wiz
Rating: 83%, 4484 votes
The only other way around is to fit a double adapter into the phone line socket and plug fax in one and the phone in other, this way both will ring and allow you to make or receive calls on the seperate handset
Rating Locked! (?) teen 37 has rated this solution as Thanks for Trying
Solution #2
posted on Sep 22, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
What mode do you have the Fax in - TAM / Auto / Fax / whatever ??
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP HP Digital Sender 9100C Multifunction Printer p/n C1313A Fax Machines HP 1010 Plain Paper Inkjet Fax HP 1220 Plain Paper Inkjet Fax HP 1020xi Fax HP HEWQ8096A Color Inkjet Fax Machine,33.6Kbps Modem,16-3/4"x8"x7" Panasonic PANAFAX UF-6000 Fax Panasonic Panafax UF-780 Plain Paper Laser Fax
Can you Help with these Fax Machines problems?
Fax Machines
I need to get into
I need to get into my original... Answer This...
Fax Machines
How do I set up
How do I set up the speed dial... Answer This...
Fax Machines
installing a linksys wireless-n...
installing a linksys wireless-n... Answer This...
Fax Machines
Fax - model number X5435
Fax - model number X5435 -... Answer This...
Minolta MF1600E Plain Paper Laser Fax
Minoltafax 2800
I got a Minoltafax 2800 in used... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
