Question about Dell UltraSharp 2407WFP 24" LCD Monitor
Dell 2407 a04 Turns on (for 2 seconds) then off
The problem is basically when I turn the monitor on, it powers up, the screen comes on perfectly (full resolution, brightness etc) for about 1-2 seconds and then the screen shuts off. It's just the screen itself that shuts off off, the row of LEDs stays on, so it's still drawing power. Any ideas/solutions would be really helpful. Thanks!
  • 1 more comment
  • Yook Sep 08, 2007
    It's not anything like that, it's the monitor itself. Even when the monitor isn't hooked up to a PC (The monitors menu screens etc etc) at all, same thing as above applies.
  • Yook Sep 15, 2007
    This turned out to be a backlight inverter problem. I managed to buy a new one from a broken 2405 and with a bit of hacking, got it to fit in where the old one was. The monitor works perfectly now!
  • DRay9911 Feb 06, 2008
    I am not sure if this site is still active, but I came here through a
    google search. I have had a 2407WFP for a year (received it the
    first week of 2007) and I get home from work yesterday and my monitor
    goes dark. The power light is still on and I switched back and
    forth between the VGA and DVI cables. If I turn off the monitor
    and then turn it back on, I will see my desktop for a second or two and
    then it goes off again. Because I received this monitor as a
    gift, I do not have any purchase information so Dell lack of Customer
    Service was no help at all. It's probably out of warranty anyway
    (I doubt the company I received it from purchased an extended
    warranty), which is fine. It's a damn shame Dell's Customer
    Service sucks so hard.
I found bluegreennash's suggestion when my LG L222WT screen kept blanking out. It took a few try's of shutting down the screen, changing the resolution while it did open for a few seconds then unplugging the monitor and shutting down the mac. I plugged in the monitor then rebooted and changed the resolution back from 640x480 and, touch simulated wood, it seems to be holding its own. It didn't work when I only rebooted, it seemed to need the monitor unplugged as well.
Posted on Jun 03, 2008
  • 661 Answers
Your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Posted on Sep 07, 2007
  • Gareth Cockram
    Gareth Cockram Sep 15, 2007
    possibly it's a backlight falure, this can be a real problem with LCD screens as they require a "backlight" to shine throught the display matrix, it is possible that teh system that energises these backlights has failed,
    you can check this as if you look closely you will still be able to see changes in the screen when things are happening, it's just that there is no light to illuminate the picture
Dell Ultrasharp 2407 monitor - Vertical lines
most likely capacitor problem as these caps only have a 25000-40000 hour life span. when you do replaace the monitor , turn it off when not at the computer. even though it goes into sleep mode there is still a current running through the unit cuz if you move the mouse or hit button on keyboard display wakes up. I know this because I have done boad level repair on panels
Feb 04, 2013 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
2407 screen goes black
faulty connector... need to call a repair guy to solder a connection.. usually 50 bucks
Apr 20, 2012 | Dell UltraSharp 2407WFP 24" LCD Monitor
I have a Dell Monitor 2407 WFPb. The monitor went black unable to locate the various adjustment button (that you can only see when monitor is bright-because it's black unable to locate them, unable to...
Try unplugging it from the electrical outlet for about 25 seconds. Then plug it back in and go to your settings if the power button turns the monitor back on if it does not work try it on another working computer. Sometimes this happens when the settings are two high of resolution when your graphics card cannot handle it. Hopefully the issue is not the monitor going bad. Thanks for using FixYa! Do not forget to place a vote for me if I helped you in any way. John
Mar 25, 2011 | Dell UltraSharp 2407WFP 24" LCD Monitor
Dell monitor E177FPc - light comes on green but immediately turns steady amber and screen is black. this has happened before and I can't remember how we fixed it.
Dell monitor E177FPc - light comes on green but immediately turns steady amber and screen is black? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
Nov 15, 2010 | Dell E177FP LCD Monitor
Dell 2407 WFP monitor Flash Memory Card Reader does not
if on the card it is written SDHC then it means that the card reader doesn't support SDHC cards, for 100% compatibility try a 2/4 Gb card with only SD markings on it not SDHC.
May 25, 2010 | Dell Computers & Internet
Monitor comes on for a split second , and then off
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor turns on and turns off 2 seconds later
compnerdtuls, You have a monitor with a sick "switch-mode-power-supply" ... It goes into PARTIAL or FULL shutdown mode because it has detected a FAULT CONDITION with itself or the inverter circuit. Why don't you go and watch some productive video clips at youtube to see if you might be capable of doing the repair or contracting out the work needed to bring your unit out of the BLACK SCREEN Of DEATH mode. You may even want to visit (FYI) a site that may have some info on possible cause of your monitor's symptom, www.ccl-la.com/badcaps.htm . I'm 12fixlouie on fixya.
Dec 05, 2009 | Dell E156FP 15"LCD Monitor
Monitor Screen goes black every few seconds!
Check the capacitors on your monitors circuit board. If they have opened up at the top, they are fried. Buy new ones, make sure nothing has leaked from the old ones, and replace them.
Sep 26, 2009 | Dell SE198WFP LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell e172fp flat screen
check the power if 110 volt or 220 volt
Jun 05, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell UltraSharp 2407WFP 24" LCD Monitor Logo
880 people viewed this question
Alun Cox
