Manufacturing defect in samsung air conditioner
The PCB is found faulty. Programming is not done properly. sensor is not working properly. there is usually a problem of leakage from the indoor unit of the AC there is also Ice formation in the indoor unit of the AC. We have complained many a times in the samsung, they came n tried to rectify the problem but since the manufacturing defect cant be resolved the problem remained as it is.
  • 2 more comments
  • Anonymous Mar 09, 2008
    my air conditioner split system leeks water inside from the unit
    Could you tell me why and what to do to fix it
  • Anonymous May 26, 2008
    Ice is forming on the indoor unit radiator, and even when the outside temperature is around 25 degrees Celsius the unit isn`t able to lower the inside temp. below 23 degrees Celsius. The symptom is manifesting at any given outside temperature. The heating mode is working properly (done also by the compressor).
  • meran Jul 21, 2008
    my samsung 9 btu when i on it.only the melody or music sound come out but the blower still not start or can u tell me what is the faulty here .is the sensor or pcb board ?
  • neelSACHAR Apr 12, 2009
    Forming of ice on the fins and pipe. this started two yrs back
Ice formation in front portion of window ac. not enough cooling effect.
Posted on Jul 23, 2009
Good info there! The culprit is usually a dirty blower.
Posted on Jul 01, 2010
Nothing can be done for this except to replace the control unit.
ask them to replace the control or replace the unit. chk if it is in warranty.???
Posted on Feb 01, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
I would get them to fix it for free or SUE!!! as long as it's a manufacturers defect and you can prove it then you can sue.
they have to fix it or else.
Posted on Nov 21, 2007
After I replaced the pcb on my samsung air conditioner indoor unit it won't start and all 3 led's are blinking
I have had similar problems with Samsung. Apparently, the indoor board fits a lot of different models and each has to be "programmed" in to suit your model. Not sure what was wrong with your machine before but it has been known for these units to have a faulty outdoor fan motor which causes the outdoor board to fail as well. When this happens, the indoor unit will usually work fine for about a minute or 2 and then shut down, with lights flashing. The outdoor wont start at all. If these were the symptoms, I would suggest putting your old indoor PCB back and then getting a new outdoor fan motor and outdoor PCB.
Apr 19, 2015 | Samsung Heating & Cooling
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Nec split system air con will not respond to remote control.
Remove batteries and replace with new batteries and restart. If still problem, unplug DC wire to indoor display sensor and plug it after a minute. Now try with your remote. If still problem, try with another remote. If no result, PCB receiving sensor defective. Replace display sensor or PCB
Jan 27, 2011 | Heating & Cooling
Error message CH47
Compressor discharge sensor fault. Disconnect from PCB measure resistance. 237 kOhm at 20°C and 168 kOhm at 30°C. If OK replace PCB, if not replace sensor. Thanks, helpful?
Jan 25, 2011 | Samsung AS18A6RB Air Conditioner
Greeting, I have problem with SAMSUNG air condicioner inverter. The display shows me an error E1 A1 and does not include the external unit, please help what is the problem.
E-1 Room sensor and A1 Indoor PCB fault. Please you replace first,indoor sensor and reset.Sometimes indoor pcb shows fault code due to sensor short. After replacing sensor it will show only A! or sometimes no error. If it shows A1, you have to repair/replace PCB. Helpful?
Jan 24, 2011 | Samsung AW1203B Air Conditioner
Mitsubishi electric, AIR CONDITIONER model peh-8,10, 12myc ERROR CODE E6 ,
E-6-Indoor unit heat exchanger sensor [ThIR] defective (resistance is open circuit or closed circuit).
• Poor connection of sensor connector on the indoor PCB.Rectify or replace sensor.
Jan 04, 2011 | Mitsubishi Heating & Cooling
Heating & Cooling Logo
447 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
