Question about Alpine Natural Air 100 Air Purifier
Alpine Air purifier
I have an Alpine - Eagle 5000 There no service center available and the company probably went under. It keeps blowing the 2amp fuse. Where should I look for the troubled spot? Thanks
How do you clean the fan blades?
If it is not easily accessible, Id recommending taking it outside and blow it out with a air compresser that has a blow spout attachement on it, if that is not available, most towns have tire changing companies that sell used ties, most of these places would be willing to blow it out for you for a few dollars im sure, sometimes thinking outside the box can save you some money on the long run.
Hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 14, 2013 | Alpine Natural Air 3000 Air Purifier
Power won't come on switch does'nt lite up fan does'nt work
First, are you sure that outlet that the unit is plugged into really works? The other situation would be a blown fuse on the back of the unit. Also, make sure that the filter on the back of the unit is seated properly and making contact with the safety switch. Check all three things. It could be any of them.
May 13, 2011 | Alpine Air Eagle 5000 Air Purifier
Does not turn on? looked at fuses and then inside the unit I noticed I only had two of those screens inside.
Guy, there's only supposed to be 2- Ozone Plates/Screens in the Eagle 2500. The reason it probably would not run, is when you took the aluminum filter off the back, you failed to reinstall it properly. Look at the bottom edge of the filter. You should see a plastic prong sticking out. That's sort of a trigger. If you don't fit it in the slot on the housing of the cabinet properly, it won't trigger the safety switch and allow the unit to run when you turn the switch on the front ON. Just make sure the prong is much tightly into the unit.
Hopefully that will solve your problem.
Feb 16, 2011 | Alpine Air Eagle 2500 Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
I have an Eagle 5000 air purifier. Stopped working
Just went thru this Tues. Get the top of screen in place and then push the plastic in on safety switch. I was having it push down and then slide screen in. That plastic piece is split like when you push it in, it hits 2 different heights. Instead of pushing it down get top in and push the plastic in, easy. Turned on then. Already had the switch on so it fired up soon as I pushed it in.
Jan 15, 2010 | Eagle Advantage Alpine Air Purifiers Eagle...
What order to the 3 wires go on the on/off swith. ther is a purple, black and orange wire
found my note with the info i needed. neveremind and thanks for your help.
Oct 01, 2009 | Alpine Air Eagle 2500 Air Purifier
The ozone generator quit working. What is the problem and where can I get parts ?
You can pull off the rear filter, pull the ozone plates, defeat the safety interlock, turn the unit on, and place a screw driver (holding the plastic handle) one one of the ozone bars, and try to make an arc between the screwdriver and the other bar.
If you get an arc, the ozone plates are dirty. Clean well with a brush and sudsy ammonia. If no arc, either the hv transformer is bad, the main circuit board is bad, or the ozone control is bad.
There's one other thing you can check: The two wires that connect to the ozone bars can arc to the chassis sometimes. You can inspect the insulation on those wires to make sure it is intact.
May 12, 2009 | Eagle Advantage Alpine Air Purifiers Eagle...
I need Alpine Air XL-15 Air Purifier Repair service
Best bet is to call EcoQuest at 1-800-989-2299 and they can direct you to the closest repair center.
There is also a way to upgrade to a newer model the FreshAir 2.1 getting $100 back for your old XL-15.
To do this go to www.healthylivingia.com or call 1-800-798-6925 and ask for Eric.
Jan 13, 2009 | Alpine Air XL-15 Air Purifier
Parts for a eagle 5000
I have some parts in stock and can order ones that you need.
Becky
716-652-6053
horninghealthyliving@live.com
Jul 23, 2008 | Eagle Advantage Alpine Air Purifiers Eagle...
Alpine Natural Air 100 Air Purifier Logo
97 people viewed this question
Top Alpine Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you an Alpine Air Purifier Expert? Answer questions, earn points and help others
