Group listing wont work and not able to select on predictive texting.
Help is needed I cannot get any groups to work on my group contacts, the instruction manual is rubbish, the contacts groups i set up will not save.
The T9 predictive texting is no use either it wont allow you to select alternatives from the word on show e.g with a Nokia you can select from a range of words when using predictive text. with this phone i cant seem to work out how to do it.
any idea how to change the number of rings before it goes to answer machine not in the book either?
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax. 2. Touch Send Now. 3. Touch the telephone symbol to access its phone book feature. 4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts. (Note: Contacts should be established before any of these could be added to any group.) 5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group. 6. Touch Name. 7. Changes to contacts/groups: •Adding a contact/group: type the name, & then touch Done. ••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create". ••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then... ••Editing a Contact: touch Fax Number, enter the fax number, & touch Done. ••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Click Gmail at the top-left corner of your Gmail page, then choose Contacts.
Select contacts that you want to add to a group, click the Groups button. , then Create new.
Enter the name of the group.
Click OK.
To add contacts to a contact group:
Select the contacts in the Contacts list.
Click the Groups button.
Select the group you'd like to add the contact to, or select Create new to create a new group.
If you have multiple addresses saved for a contact, you can choose which address should belong to the contact group by opening the contact and clicking the small arrow next to the group you'd like to modify.
To create a group list under message tab you can find list option , using that first create a list , then add your contact details in that list ,while sending message you can choose to send to group or list ,so that you can send to many at same time you can make a group text.
Groups can contain any
number of contacts, and even just a single member, so you could, for
instance, have one ringtone for family members, one for work colleagues
and one for your partner. To create a group, assign a ringtone and image and then select a group's members, follow these instructions:
From the main menu, highlight Contacts and click Select.
Highlight Groups and click Select.
Click Add (or if you have already added groups, click Options, highlight Addnew group and click Select).
Enter a name for the group and click OK.
Highlight the group's name in the list and click Options.
Highlight Group details and click Select.
Highlight Group ringing tone and click Select
Highlight Open Gallery, click Select, locate the ringtone in your gallery and click Select to apply.
Highlight Group image and click Select.
Click Add, highlight From Gallery, click Select, locate the image in your gallery and click Select.
Now highlight Group members and click Select. Click Add and your contacts list will open. Highlight the contacts you want to add to the group and click Select. You can add as many contacts as you like to each group.
If you want to add contacts to an existing group, highlight the group's name on the Groups screen, click View and click Add to display your contacts list. Highlight a contact and click Select to add them.
open your gmail account than click on "contact" on the left side this will bring you your contact list. choose the group where is situated the contact you want to move. than select that contact than click "groups" and choose the new group you want to move the contact in from "add to". Now this contact is linked to two group cathegories. Just do same and select "groups" than "delete from" instead of "add to"
you can find list option under message tab , using that first create a list , then add your contact details in that list ,while sending message you can opt to send to group or list ,so that you can send to many at same time using group text
Easy. Try asking a friend to text someone,and you text someone, and then ask your friend to text your other friend, and you have 1 texting group!(P.S, Your lucky you have the lg rumor)
