Question about Canon imageRUNNER 2020 All-In-One Laser Printer
Canon iR2020 Copier/Printer
I recieved a message on one of our new supervisors computer after I installed the printer. When I printed a Test Page it came up with a dialog box asking for a Username and Password. This was rather odd as this has never happened with any other computer. Now I want to reset the printer and just add in the network settings again. But I can't seem to do this. What is strange is that no Users with Passwords have been set on the printer.
  • Anonymous Nov 05, 2008
    sir somebody has change the password of that machine.that person can take the print out without any password but when we enter the password it does not accept that.
Set up wifi printing. Why am I unable to print documents?
you have to uninstall all other printer software except the epson printer software.after uninstalling all other printer software you have to restart computer
Sep 03, 2015 | Epson Expression Home XP-205 -...
How to print to Canon ImagePASS-M2 (connected to iR105) from Windows computer
If you connected it directly to a Windows computer, then, on that computer, "share" that printer, so that any computer that can connect to that computer can also access that printer.
You probably need to download software from Canon's web-site and install it on each computer that wants to print to that printer/copier.
Apr 29, 2014 | Canon Office Equipment & Supplies
Cannot Print because the version of the device controller function is old
Sometimes new OS versions are not backward compatible with older exterior hardware. Try going to Canon's website and finding an updated driver. Also try to get driver info for your printer.
Jul 07, 2012 | Canon imageRUNNER C5180 Color Copier
Canon imageRUNNER 5020 Copier not printing parallel attached
open your cd and try PrinterDriver Installer from misc folder
Apr 06, 2010 | Canon imageRUNNER 5020 Copier
My canon mf8100 series prints once, then beeps and
set the paper size to A4 in ur computer and in ur printer
Aug 29, 2009 | Canon MF8180C Color Laser MFC Printer
Canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Jun 16, 2009 | Canon iR 2022 Printer
C3100 Printing Fails from XP
Disable firewall to test if it is actually blocking. Windows Firewall should not normally be configured to block printing.
Make a new printer instance, but use a standard TCP/IP port
If that fails, install the driver using the canon setup.exe installer for you unit.
Mar 25, 2009 | Canon iRC3100 Printer
Canon imagerunner 330S
Did you need to connect the machine for printing? Sounds like you have installed an incorrect driver. You can go to and find the correct driver. Make sure you specify for the correct machine.
Feb 20, 2008 | Canon ImageRUNNER 330s Copier
Canon IR C3100n copier "NG 853" error
I had a similar problem with my MF6540. I could access the remote UI and see that the printer was recieving information via the print log. It would list all of my test pages that I tried to print but in the print results column I would get an error code NG(##5536) and the printer would not actually print anything. I tried the UFRII driver stated above and everything seems to be working now.
Sep 17, 2007 | Canon imageRunner C3100 Copier
Canon imageRUNNER 2020 All-In-One Laser Printer Logo
241 people viewed this question
old marine
old marine
