Question about NEC (MTLAMP820/1020) Projector Lamp for MT820, 102
NEC MT820 Projector
Hi, I have just replaced the lamp in my NEC MT820. I do not have a remote control for this product anymore. The 'status' light is continually red and the 'power' light is orange. The problem is that I cannot turn on the projector to reset the status of the lamp - or do anything else. It simply does not shoot any light.
  • 3 more comments
  • Lafleche Mar 03, 2008
    i have a nec mt1050 i need to reset the lamp...i have no remote HELP
  • Anonymous Mar 12, 2008
    I have replaced the bulb and Im trying to turn the projector on i do have the remote.
  • BLUNKleton Dec 28, 2008
    I have the same problem as the original post. Exactly. Any ideas?
  • jedipashley Apr 02, 2009
    projector, no remote. even bought a universal from nec, no luck!
    same thing here
  • 3 Answers
Press and hold the power button on the remote control for 10 seconds.
Posted on Jan 12, 2009
SOURCE:
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
NEC NP-M300W projector: Lamp status RED, replaced lamp still RED. Status indicator GREEN. Won't power on.
On the remote control of the projector, press and hold the HELP button for 10 seconds.
Aug 26, 2015 | NEC Office Equipment & Supplies
My nec vt59 projector is displaying control panel locked, i dont have a remote so can i manually unlock it?
can do it only with remote control
remote control USD15
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 16, 2012 | NEC (MTLAMP820/1020) Projector Lamp for...
My nec projecter lamp status is just red on and not working any idea
Usually the unit will go into permanant standby if the lamp life exceedes its safe limit. I had the MT830/1030. To reset it I had to press the off button down for upto 20seconds which resets the lamplife. If not the off button it was the on button.
Good luck
Jun 12, 2011 | NEC (MTLAMP820/1020) Projector Lamp for...
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Machine will not come on
Hi there
Sounds like a typical Ballast ( lamp's powersupply ) problem.
Mar 23, 2008 | NEC (MTLAMP820/1020) Projector Lamp for...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
NEC (MTLAMP820/1020) Projector Lamp for MT820, 102 Logo
607 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
