Question about Philips 20MF605T Television
Samsung Syncmaster 741MP
Hi All of a sudden the sound on our LCD tv has gone. We've checked all the cables are in correctly and even though the picture is perfect we have no sound.
  • 3 more comments
  • captaingriff Nov 26, 2007
    Have exactly the same problem. Only a month old and has never been dropped / damaged.
  • mermik Jan 26, 2008
    I have the same problem. Sound from the connected PC is OK, but tv has no sound, not even on the headphone-out socket.
  • markflyer Feb 10, 2008
    Same problem, sound just stopped, monitor is just out of guarantee!
  • Anonymous May 02, 2008
    I have the same problem with the 741mp SyncMaster. This is my second one as the first tv sound went during warranty. Unfortunately this one is out of warranty. Anyone have any idea what it may be.
  • Anonymous Mar 26, 2014
    NOOK NO PICTURE OR SOUND
I workin in the factory in tijuana mexico this trouble sometime its the solder defective in the ic amp good look
Posted on Aug 29, 2008
Similar problem was solved by transporting the wrong TV some tens of kilemeters by a car :-) Maybe there was some junction error inside, or a longer power-off state was needed to fix the problem?!
Posted on Feb 14, 2008
2 Suggested Answers
SOURCE:
Coldcut
  • 1554 Answers
SOURCE: All of a sudden the sound on our LCD tv has gone. We've checked all the cables are in correctly and even though the picture is perfect we have no sound.
Connect the cable directly (bypassing the cablebox)and
set menu to cable channels ,
tune to channel 3 or such and do you have sound now.
if not the amp is out , you might just consider using external speakers as they will sound better anyway.
Posted on Feb 25, 2008
Why do I have no signal on the Samsung syncmaster 940 mw tv
Check your cable connection on both ends. Try to change the cable.
Oct 06, 2014 | Samsung SyncMaster 940MW 19" LCD Monitor
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I VE A SAMSUNG LCD TV/MONITOR SNYCMASTER 932 19
can you see that a capicitor 820/10v is pluked ? replace it.
Feb 21, 2010 | Samsung SyncMaster 932B LCD Monitor
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Jul 29, 2009 | Samsung SyncMaster 940B Monitor
Moniter very lightly flashing
Problem was not solved. I am returning to Samsung. Thanks.
Jan 05, 2009 | X2Gen MG19MY 19" LCD Monitor
All of a sudden the sound on our LCD tv has gone. We've checked all the cables are in correctly and even though the picture is perfect we have no sound. SAMSUNG SYNCMASTER 741MP
Feb 25, 2008 | Televison & Video
Samsung SyncMaster 191T
Sounds like the invertor board in the monitor is bad or the LCD screen has had it and needs replacing.
Jun 04, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung LCD Monitor 740N line crawl problem
Just contact with samsung service on 1800110011/01130308282. Becouse this problem is related with LCD pannel which using in this monitor. LCD to be replace by samsung people.
Sep 08, 2006 | Samsung SyncMaster 740N 17" LCD Monitor
Philips 20MF605T Television Logo
505 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
