Question about Sony PlayStation Portable (PSP) Console
Can't convert psp files
Can't convert pc files into playable files on my psp i have a memeory stick duo max media pro how do i do it please help
    President:
  • 2,961 Answers
You need an mp3 conversion programme like Nero, or media player 10 can convert your cd's to mp3 in the rip tab. but what it doesn't tell you in the instuctions is that you should make a new folder called music in the psp folders window when it pops up showing whats saved on your psp. Make sure you have a decent size duo memory card fitted as this is where the songs will be saved; not on the psp itself. But in your psp settings make sure you have selected USB connection or it wont connect and show anything on your pc. select your mp3 file on your pc, copy it and then go to the music folder you made open it up and then select paste, it will then go into the folder and then should show up in the music menu in the psp after you have disconnected the usb lead. the same applies to video or any other file you wish to put on the psp.
Posted on Sep 07, 2007
SOURCE:
MY memory stick can be seen and read in my pc but doesnt work on my psp
  • Flash Storage:
  • Memory Stick PRO Duo Expansion Slot pspphatmodelnumber.gif pspslimmodelnumber.gif pspbritemodelnumber.gif
All flash storage, including Memory Sticks and internal flash, uses the FAT32 file system. http://us.playstation.com/support/answer/index.htm?a_id=1055
The above shows how to format the Memory Stick PRO Duo in the PSP so the correct file structure will be shown.
Be sure to back up any data on the Memory Stick PRO Duo before doing this as all data will be lost on the Memory Stick PRO Duo device.
Aug 06, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
How do you install and play games on the psp from the memory card?
If your psp has the latest firmware update, especially 3001 or Psp Go models, then you cannot download and install 3rd party downloaded software (iso or cso files)
Sony has improved on their copy protection platforms and at this time does not allow homebrew to run on the psp. this can be done with chickHEN (google it), apparently, though I have not yet tried it, as it will use resources to run it.
But, if you go to Playstation Network and purchase/download games/videoes/etc.. they can be downloaded from either a Playstation 3 (if you ownl one),
or a pc. Also you can access PSN psp downloads directly on the psp and download games directly, install them onto your memory stick pro duo or pro duo hg, etc..
memory card. there are thourough instructions on the site as well. Also, if you are using your PC to transfer files, download the Media Go software for the psp from sony.
Here is the link for Media Go Software (download for free).
http://www.sonycreativesoftware.com/products/mediago/default_enu.asp?page=download
There ya have it.
Please Remember to Rate me / Submit a Testimonial if you would. Thank You So Much!
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Not able to copy movies on Sony 8GB Memory Stick Pro Duo for PSP
Before you go throwing any old video file onto your PSP, make sure you have the following items:
  • The PSP. This is self-explanatory.
  • The .MP4 video files.
  • Video conversion software to convert non-MP4 files to MP4, the format the PSP reads.
Oct 20, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
PSP not detecting files on a 4gb memory stick PRO Duo
There are certain folders that the PSP puts on the stick when it formats it. Format the new stick on the PSP first. Then, you can transfer you files to it.
Jun 28, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
PSP not reading Memeory Stick.
If it is not a psp memory stick,or a compatible psp memory stick,IT will not work.Most memory sticks are not compatible with the psp.
Please take time to rate this fixya
May 12, 2009 | Sony PlayStation Portable (PSP) Console
Cannot view tvideo clip i made on my memory stick pro duo
1.When you finis making it convert it to MP4 file because MP4 files can only be read an the PSP.
2.when u finish convert it put it in the video and done.
3.Then unplug the usb and then go to your MY VIDEOS and there u can now watch it.
Jan 17, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
