Question about Alpine MRV-F545 Car Audio Amplifier
Sony kv-16gw1 no power,relay continously clikking
    Genius:
  • 1,139 Answers
I would suggest that you get a schematic for this device and the examine the power supply section with a multimeter.
Posted on Sep 08, 2007
SOURCE:
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-27V10, power supply getting power to first relay, power button has continuity, how do I get power to power button ?
first check for power supply operation..maybe a defective horizontal stage might caused this type of defects
Jul 15, 2011 | Sony KV-27V10 27" TV
SONY TV MODEL KV-27FS120 stand by light
if it is continous blinking.........then you have a faulty jungle IC IC301,shorted to ground,IK video path is defected,............ hope this helped
Feb 17, 2010 | Sony Televison & Video
Sony Fd Trinitron KV-32FX68E, stanby led blinks twice
odds are power supply module 150 200 repair
Dec 01, 2008 | Televison & Video
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Jul 12, 2008 | Sony KV-36FS100 36" TV
Trinitron wega kv-36fv15 - blinking light continously
yes u need services on ur tv , it could be ur picture tube , if it is your picture tube is not economical to fix
May 28, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
NOTHING HAPPENS!!!!!
power supply probel, need to take to service
May 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony kv-32fq86e 16 blinks
If red led blinks continously , please check horizontal o/p or EHT screen control reduce and check for power on
sam
Apr 18, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Alpine MRV-F545 Car Audio Amplifier Logo
154 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
