Microphone are not working for my laptop compaq presario F500
My microphones are not responding for my compaq laptop..even i did some work around for enabling the recording device..but still i could not make it..Could any one help me out of this issue..
  • 2 more comments
  • Anonymous Nov 28, 2007
    I just bought a compaq F730 laptop with vista on it and its microphpne don't seem to be working. Funny thing is that when I plugin my headset, it works fine. anyone else seen this problem or any sugggestions what could be wrong?
  • Anonymous Dec 13, 2007
    on mirc it is not working
  • tshering May 02, 2009
    mine is compaq presario CQ60 and i can't see any response from my laptop even when the mic is connected. can anyone please help me out with this problme?? please.......
    i tried in desktop, the mic did work well... i tried in other dell laptop and it worked.. but in compaq laptop, i don't know whether the problem is with driver or other things, in any ways i tried, it didn't work... can any one please help it out..
SOURCE:
SOURCE: Having compaq presario c700 facing cound problem......
I have solution for Compaq Presario C700 C734tu Laptop. In My laptop Sound was working properly, only the problem was MIC was not working. So after googling I found this link for Sound Drivers. It may help you.
http://webpages.charter.net/mmooglemirror/Compaq%20C751nr%20Audio%20XP32.zip
Regards,
Alpesh Bhavsar
Posted on Aug 13, 2008
toddg
  • 171 Answers
SOURCE: Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Posted on Sep 24, 2008
antilez
SOURCE: microphone Presario C700 not working
Just download audio driver from this link
http://www.mmoogle.org/compaqc751nrwindowsxpdrivershowto
I am sure it will work.
Posted on Nov 15, 2008
  • 31 Answers
SOURCE: cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Posted on Mar 17, 2009
onlinehelps
  • 14 Answers
The first thing that I suspect is that it couldn't locate the right drivers for installation. Still, I'd suggest that you try reinstalling the right drivers for you laptop. There's no harm reinstalling the drivers. Get the drivers for V2000 at this link, but you need to choose which OS are you using: Presario V2000 Audio Drivers. Take note too, that HP recommends that you delete your existing drivers first before installing the new ones.
The method of deleting and reinstalling can be found at Method 4: Delete and reinstall the original sound drivers of this LINK. That link includes the troubleshooting methods for audio/sound problems. You can go through the procedure that applies to you, but I'd still suggest that you do first METHOD 4.
Please let me know of your troubleshooting success by rating me here, or visit me at http://howtoresolve.blogspot.com or at http://real-online-treasures.blogspot.com .
Good luck and enjoy!
Posted on Mar 18, 2009
Microphone not working
Is the microphone enabled? Right mouse click on the loudspeaker icon, (bottom right on desktop). Select Recording and check the mic volume is enabled.
Mar 04, 2013 | Compaq Presario F500 Series Laptop...
PRESARIO F500 MICROPHONE NOT WORKING
Check the sound driver is installed and the microphone volume is turned up in the desktop mixer.
Is the microphone available on compaq presario V6000 model for using skype
Any "modern" laptop will either have a built-in microphone,
or it will have a small "microphone-in" socket where any separately-purchased microphone can be connected. Look for a small hole with a PINK ring around the hole.
Jan 02, 2010 | HP Compaq Presario V6000T 15.4" Notebook...
Microphone not working for presario c700
If it has Realtek device drivers check through that not WDM. Also, make sure you set the record settings for the mic to select it, not the play settings.
Jul 25, 2009 | Compaq Presario 700 470024-192 Notebook
External microphone jack wont work
HAve you tried going into your mixer, by clicking on the sound icon at the bottom right of your screen, selecting microphone, and making sure its not on mute. it is on mute by default, you may also find a switch to apply more dB to the signal, you should try this and see if this corrects your problem
Feb 18, 2009 | Compaq Presario 1800 Notebook
Microphone is not working
i have compaq Presario c700 laptop
but my external microphone is not working & also inbuilt microphone is not working.
Feb 02, 2009 | Compaq Presario 700 470024-192 Notebook
Problem with micerophone of compaq c773tu
You Have To Hook Up A Mic Cable From The Rear Of The Monitor To The Modem.
Jan 06, 2009 | Compaq Presario 700 470024-192 Notebook
Battery charging
you need to replace the battery, don't leave your laptop plugged in when not in use, it will reduce the batteries life and eventually it will fail.
hope this helps
thanks for your rating
Jan 07, 2008 | Sennheiser Charging Station for BA2015G2...
699 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
