Question about Foxconn 6627MA-RS2H Motherboard
Problem with FOXCONN 662 7MA Motherboard
I have internet cafe, and i have a 15 PC's with FOXCONN motherboard. Five of them don't work, they don't boot even the bios, some others restart the pc's (Many time they restart when the customers try to login on Windovs Live Messenger)... My hardware is only GeForce 7300 Le, 512Ram, and 80GB HDD (only), so I can't find the problem more then 5 mounth's... Pleace tell me what to do?! On some forums i see that the hardware is uncompatible, but in my case that is imposible (i think) because other 10 PC's work great. Thank's for understanding! My email is m.pelovic@gmail.com
  • Anonymous Nov 15, 2007
    no entra el rakion anteriormente si estaba func
Bota eso a la basura y comprate una placa madre de calidad como Asus, MSI, Intel entre otros...no seas tacaño... la diferencia de precio no es mucha pero los beneficios si lo son.
Posted on Apr 27, 2008
Hello
I have reinstalled windows. Then when I will installed motherboard driver it did not be installed.
The CD-ROM has not driver: intel chipset driver version 7.3.0.1012
My motherboard: foxconn 6627MA
Miloud Si larbi
Posted on Mar 12, 2008
  • Miloud Mar 12, 2008
    hello
    Miloud Si larbi
    Brigadier General:
  • 6,966 Answers
Hi, Sorry to say that this board has so many problems associated with it specially the SiS chipsets, that you might be better of replacing them since they should still be under warranty. If you swing swing a replacement of another brand/model even if you have to add a little, that might be a better solution rather than force the issue of repair. Offhand the most that you can really do is check if you can upgrade/update the BIOS and see if there is a significant improvement. Other than that you have little or no other options. If replacement is viable, try to get motherboards with Intel or Via based chipsets. Good luck and kind regards.
Posted on Sep 07, 2007
  • Louie  Role
    Louie Role Sep 09, 2007
    Hello again Marko,
    We have the same business.
    The sooner you have them replaced the better. You may have to spend a little more to have the brand/model replaced assuming that your supplier would agree. Asus, MSI would be good brands as well as ECS as long as the chipset is either Intel or Via. Experience has taught me to stay away from PC Partner, Jetway & FoxConn.
    "Did I have a way to change only chipset?" unfortunately no, there is no easy way to just only replace the chipsets.
    One thing that I have found to be very helpful in a Comp Rental (Internet Cafe) business is to have a spare hard disk with OS, applications, games installed identical to the HDs used in the active PCs. At any given time, I don't bother with repair, I simply clone the spare HD to the PCs HD which reduces the downtime and the tech work/man hours. For partitioning/formatting, I use PowerQuest PartitionMagic; for cloning, I use Acronis True Image. This is of course assuming that all the PCs have identical hardware setup.
    Cheers.
Need help finding part for Evesham desktop that want connect to my tv. i have found my motherboard model which is foxconn-945g7ma, however when i search for it on the internet i find two types Foxconn
You would only be able to connect that to your TV if your TV has a VGA connector, (also called D-Sub.)
There is NO HDMI or DVI connector on any 'flavor' of that model Motherboard.
Mar 29, 2014 | Evesham Computers & Internet
FOXCONN MOTHERBOARD UYD761904374 PC661M04 MX 6L Will NVIDIA GeForce 9300 GE graphic card work with Foxconn motherboard UYD761904374 PC661M04 MX 6L. Please help me. I want to install windows 7 and use...
System Ram doesn't count for Gpu ram so 2 gig Ram and 2 gig Gpu will be fine .. check also Psu some Gpu are hungry for power Mine is Gtx770 8 pin + 8pin at 240watts.. hence 750 watt Flower power Psu...
Jul 01, 2017 | ASUS Computers & Internet
Pc doesn't boot up
do you have the right memory to match the cpu
Mar 31, 2010 | Foxconn G31MXP-K Core 2 Quad/ Intel G31/...
PC INTEL P4 /Motherboard foxconn 661fx7mi-s DOES NOT POWER ON
Seems like the motherboard is broken...
Yous hould first try the PC with another motherboard, if you have one and are able to switch all the components.
If then the PC boots, the motherboard is broken. You could try taking it to a computershop, maybe they can spot a problem, but I guess if something, like a fuse or a single wire, burnt through the only way to fix it is to replace all of them, which would be more exoensive than a new motherboard.
If you need any help finding a new motherboard just ask me.
Jul 22, 2009 | Foxconn Computers & Internet
Foxconn n15235 mobo will not post nd gives long beep
i think your motherboard is your problem... check your motherboard to other systems.
Apr 15, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Boot up problem
Dear topman1100,
May there could be the problem with u r RAM. Pls check the RAM or change the RAM with u r friends computer's RAM so that u get know that problem with u RAM or not.
Regards,
Bittu_8
Feb 16, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Foxconn 661mx plus
blue screens means you have problems with your operative system or memory so make sure your operative system cd is in good coditions and reinstall it
Dec 31, 2007 | Foxconn 661MX Motherboard
Foxconn Motherboards Led Boot display
Without more detailed information, I really can't help you decipher that code... Since you don't know which specific Foxconn motherboard you're working with, it might be best if you contact Alienware Customer Support for detailed information:
http://support.alienware.com/Support_Pages/Support_Area.aspx
Good luck; let us know what you learn...
Nov 21, 2007 | Foxconn (865G7MC-ES) Motherboard
Foxconn 6627MA-RS2H Motherboard Logo
1,178 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
