Question about HP OfficeJet 6110 All-In-One InkJet Printer
The led between the buttons cancel and lighter-darker is turning on when the office jet is switch on, what i have to do for making the machine works again?
  • nimal Dec 04, 2007
    Paper jam indication is shown on the LCD screen even without any such jam or any paper put into the printer.
  • 83 Answers
What's on the lcd screen? Maybe some paper jammed inside printer?
Posted on Sep 08, 2007
SOURCE:
When I want to print it says error 6C10 switch off switch on. Doesn't work!
that indicates full waste ink pads/absorbers. to reset the counter try this:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
any way if the absorber/pad is full, it have to be cleaned!
Sep 20, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
Ink aborber is full I have clean & changed the ink absorber but again it is giving the same message MX 308 error 5B00
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Waste ink counter resett)
Should fix you right up!
Jun 27, 2011 | Canon MX300 Office All-In-One Printer
Getting Waste Ink Asborber is Full message, What do Ineed to do to fix it?
The waste ink absorbers are usually small pads at the bottom of the printer. You need to pull them. This is usually messy and can require basically taking apart the printer. Then either replace (contact a service center) or rinse clean the pads (just running water works). Once the pads are dry (if reusing them), reinstall them.
Then reset the counter:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Do not do the reset until the ink absorber is cleaned. The waste ink will get everywhere in the printer and the pages you print.
I hope this helps.
(most ink jets are really designed to be replaced if the waste ink absorber is full - the other parts may soon fail too.)
May 02, 2010 | Canon PIXMA iP90 Mobile Printer
Re my pixma mp13o printer. message"ink waste tank almost full" how do I rectify it. tried switching on and off and unplugging for 10 seconds.
Three choices. 1. Take it in for repair. 2.Take the top off and remove and clean the pad. 3. Use the following instructions to reset the printer and continue printing. I chose number 3 and haven't had any problems.
These are the instructions which worked for me on my Canon mp470 and has work on many other Canon models:
1) Close the print2_bing.gif head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
Mar 24, 2010 | Canon PIXMA MP130 All-In-One InkJet...
THE INK ABSORBER IS ALMOST FULL
Canon iP4500 waste ink reset:
1) With the machine power turned off, while pressing the Resume/Cancel button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Resume/Cancel button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Resume/Cancel button 2 times, and then release both the ON/OFF and Resume/Cancel buttons.
4) When the Power LED lights in green press the Resume/Cancel button 4 times
then press the ON/OFF button.
I found this info by googling iP4500 waste ink reset. It is the same procedure shown in the service manual for the iP4200 and the MP610. In the MP610 service manual it says after the reset it will print a page: ("D=000.0" is printed at the top left of the paper.) I don't know if the iP4500 does this page print, so you might want to have at least one sheet of paper loaded just in case.
Nov 12, 2009 | Canon iP4500 Photo Printer
The printer is showing "waste ink collector full",not printing
Most cannons reset the same try this:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is not installed, the
carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green (Power) EEPROM information print
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
>>>> 4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings [hth: not applicable]
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes
May 07, 2009 | Canon Bubble Jet S900 InkJet Photo Printer
I have a bell south phone model# 8823 which has been discontinued and i don't have the instructions anymore i need to know how to make the screen appear clearer so i can read the numbers. All i remember is...
press the menu button, then press the down arrow until it says "set contrast" then push the menu button again and then push the up arrow for darker contrast, the down button for lighter. when finished, push the menu button again
Dec 01, 2008 | Lands Phones
Changed ink jets alarm flashing number 5800 showing
Hello Saron Girl,
its not 5800 its 5B00
7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
4 times LED Green Waste ink counter resetting
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
Regards,
May 14, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Hp Office Jet 4315 cancell a fax number?
go to the fax number, then try pressing the X button. Other wise if u are ready to loose all numbers, just reset the machine
Jan 08, 2008 | HP Officejet 4215 All-in-One Color Photo...
Canon i70 LED
The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
Try This
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Dec 18, 2007 | Canon BubbleJet i70 InkJet Photo Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
26 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
