Question about HP Compaq d530 SFF PC Desktop
Uncontrolled CPU Cooling Fan Speed
CPU cooling fan speedis always constant. Earlier it is changed according to CPU loading.
  • Anonymous Mar 21, 2014
    CPU fan is noisy
  • 944 Answers
Here is the link for all the various support manuals, software and instructions for your PC if you need them; http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=179911&taskId=101&prodTypeId=12454&prodSeriesId=316713 CPU fans should be plugged into the CPU fan power socket on the motherboard, in order to receive variable speed control instructions. If the fan has been incorrectly connected to a different motherboard fan socket, or directly to the power supply then it will run at a constant speed. If it is correctly plugged in to the correct socket, then the hardware management software (there are many possible options here - please post back with which management software you are using and I can give more specific instructions) that comes with the PC should allow you to change the settings - you can change the temperature range at which the cpu fan will go into higher speed mode - it sounds like you may have this set too high You should also be able to control the fans from the BIOS set-up menu - this should be accessible when you boot up. usually it will be by pressing F8, but all systems are set up slightly differently. watch the screen as you boot up and it should give instructions for this. Hope this helps, please give more details of how your machine is set up if you need more specific help :)
Posted on Sep 07, 2007
The problem with this model is dust. Remove the fan and heat sink, clean out all the dust. The fan will run at variable speeds again.
Posted on Nov 22, 2007
How do I check the CPU cooling fan setting ? How do I access the TV tuner ?
Is it full of dust and the motherboard has maxed the speed in an attempt to cool it? Otherwise, go into your BIOS and confirm that the fan speed controller is enabled. The Control Panel in Windows may also have a setting.
Oct 16, 2014 | Computers & Internet
Laptop cooling fan running at very high speed
Try loading and using a program called speedfan to control your fan speed if that is appropriate. This can also show you your CPU temperature (if you can figure it out). Core Temp can show you temperature of modern CPUs, amongst others.
Otherwise try cleaning you CPU of dust - search the internet as to how to this safely.
18.April.2014
Feb 05, 2014 | MSI pr600 fan
I am using a Dell Dimension C521 Desktop and the other day I noticed the fan started constantly entering a cycle where it would kick into high speed and then slow down again every 2 minutes. After trying...
The fans change speed depending on the temperature the sensors detect.
Give your machine a thourough cleaning.
The CPU sensor is usually located under the CPU if it's loaded with dust it may think it's hotter then need be and kicks the fan up.
Feb 24, 2011 | Dell 90MM X 90MM X 32MM Computer Cooling...
My computer runs constantly its loud and annoying
I assume you mean the cooling fan on the CPU, this model uses a smart fan technology, it is meant to spin up faster to provide cooling. If is is doing tis constantly, it means the CPU is not getting adequate cooling (overheating), to check this, remove the side panel, clean all the dust and debris build up from the cooling fan and see if that helps
Jan 22, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
How to adjust cooling fan speed
no. The factory defaults set to right cooling temperature. It automatically adjusts the temperature. If your processor is cool fan automatically offs. So dont worry about that
Jul 02, 2010 | Acer Aspire 5720 Notebook
Compaq presario cpu cooling fan will not start spinning unless "helped" with tip of pen to spin over.If I dont start it manually,I get No cpu fan message,and shut down.I just replaced fan,as old had broken...
If the CPU fan speed is too slow or not working at all, the computer will shut itself off automatically to prevent damage to CPU from overheating. You may end up having to throw more money at the problem and get a new fan. I went to Compaq's web site, looked up your particualr computer, found out what type of fan you needed, and I did some research. I recommend getting the fan in the following link. It's very cheap, and has good reviews. The other fans on the site all have bad reviews. Hope this helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114011
Jan 12, 2010 | Compaq Presario Cooling Fan CPU Heatsink &...
Cooling fan running constantly.
the cooling fins are clogged, u need to get a small vacum and clean the area
May 09, 2009 | Computers & Internet
Cpu fan running at high rpms
Are you sure there is enough thermal jel between the new cpu and the fan? If not, fan could not get enough heat and constantly tries harder. That thermal jel creates a better environment for the heat conduction so that fan could do less job and take out more heat at the same time. Hope this will help.
Apr 14, 2009 | Computers & Internet
Uncontrolled CPU fan speed
Make sure you have used the proper Fan connection on the motherboard and that you used all the pins in it. Usually it consists of 3 to 4 pins for CPU fans. Does your Fan have 3 pins? If not then it is not compatible for Fan Speeds. Also check your BIOS for Fan adjustments. Hope this helps.
Sep 15, 2007 | HP Compaq d530 SFF PC Desktop
HP Compaq d530 SFF PC Desktop Logo
650 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
