Question about LG Goldstar GWHD5000 wall/window Air Conditioner
Cooling part ig gone - LG Goldstar GWHD5000 wall/window Air Conditioner
    New Friend:
  • 4 Answers
No water is needed for this model, you can refer to user manual.
http://www.helpowl.com/manuals/lg-gwhd5000-owners-manual-6758147.pdf
Posted on Oct 22, 2013
SOURCE:
1993 toyota camry
See here for all the checks you can do on the ignition system. You will need a good multimeter
http://www.turboninjas.com/camry/ig.pdf
Mar 27, 2015 | 1993 Toyota Camry
Hey there, 2005 Hyudai Santa Fe, with multiple codes. p0320, p0300, p0301, p0302 thru p0306. any ideas please? Thnaks' Greg
Each one of the codes indicate misfire, except p0320.
1. Check IG failure sensor (1) Connect IG failure sensor and PCM connector (2) Engine "ON" (3) Check that RPM meter on instrument panel is operating correctly and the signal waveform of IG failure sensor at terminal 4.
m0320-8.gif (4) Is the IG failure sensor normal? YES ??¶ Substitute with a known - good PCM and check for proper operation. If the problem is corrected, replace PCM and go to "Verification of Vehicle Repair" procedure. NO ??¶ Substitute with a known - good IG failure sensor and check for proper operation. If the problem
Jun 29, 2011 | 2005 Hyundai Santa Fe
On a Honda CRV-2000 clock module (working intermittently, no fuses are out), there are 4 connections: B+, IG, LI, and GND. I'm assuming the B+ is a fused connection from the 12V battery. What are the IG...
Ignition and headlight illumination (clock should dim when wired to IG/+). The clockshould be bright with it disconnected and dim with it connected to +/IG. If it is dead in all cases, I offer a repair service, check out www.autoclockrepair.com.
Feb 28, 2011 | 2000 Honda CR-V
Has new alternator and battery but still drains battery when running till its dead
check the vehicle, something is on constant, ig power window motor has gone bad and is on constanly althou the power window is not moving, check the windshield wipers motor, do a visual inspection of the vehicle.
Nov 10, 2009 | 1993 Jeep Grand Cherokee
1995 honda stops running and won't kick over after it stalls
WELL THIS JUST MIGHT BE THE IG NITER IN DISRUPTOR THE GET WARM AND THE CAR DIES THEN IT RESTARTS AFTER IT COOLS HOPE THIS HELPS
Aug 07, 2009 | 1995 Honda Accord
Overheating problem, fans not running when up to temp.. Temp. sensors okay, where is ECU IG fuse located on this car.
If the fans are not running, the problem is most likely the relay. You can test relay with an ohmmeter. If fuses are ok, than the fan motor will need to be replaced.
May 23, 2009 | 2001 Lexus ES 300
LG Goldstar GWHD5000 wall/window Air Conditioner Logo
75 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
