I have a database built. In the Form I enter a Center and in a seperate box the County it is in. When I send out my surveys each Center is assigned a number that is only for that Center. I want to speed up my data entry, so I'm wondering if there is a way to simply enter my assigned numbers so that when it is entered, it will come up as the specific County and Center for all of my reports. Can this be done with a query or a Macro? I figure I would have to build a spreadsheet for the program to reference but I don't know where to go from there.
Comments:
Apr 21, 2009
- Ok made the tables. Did the relationship. In the fields on the form I went into the properties and selected the same fields from each table for the Control Source. This didn't work. I tried putting the and in between the fields in the Control Source window and it didn't help. It gives me "#Name?" in all the fields when I run the form. Did I miss something? Also I did not see a way to make sure that the relationship goes from Main to Center table. This may be part of my problem too.
You need to create 2 tables. Create one table with just the Center Number, County and Center fields, using the Center Number as the primary key, lets call this table Center. Then create the other table with all the other fields you need, lets just call it the Main table for now.
Then create a relationship between the Center table and the Main table using the Center Number for the relationship. The relationship should be a One-to-Many from the Main to teh Center table. When creating the form, you take the fields from both tables. When you input the Center Number, the County and Center should be automatically filled in.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Microsoft Office Access 2003
Hey everyone. Can anyone help me come up with a script that will allow me to import a text file...
(More)
Hey everyone. Can anyone help me come up with a script that will allow me to import a text file that's in the format shown below? I'm trying to import this file into an Access database table. The file has spaces between each line which is what is giving me a fit. Please look at the file layout and example below. Text File Layout: a = Lockbox #: (6) digits and (4) leading spaces. Postions 1 - 10 b = Site ID: (2) digits and (8) leading spaces. Postions 11 - 20 c = ISA #: 10 spaces. Postions 21 - 30. Not used currently d = Cust #: 5 spaces. Postions 31 - 35. Not used currently e = RG Key: 11 spaces. Postions 36 - 46. Not used currently f = Tran Code: (4) digits (4) spaces. Postions 47 - 50 g = Record #: 4 spaces. Postions 51 - 54. Not used currently h = Count #: 2 Spaces. Postions 55 - 56. Not used currently i = Volume (17) digits, zero padded to the left of volume. Postions 57-73 j = Dollars (14) digits, zero padded to the left of volume. Postions 74-87 k = Description: 240 spaces. Postions 88 - 327 l = GL #: 23 spaces. Postions 328 - 350 m = Adjustments: 3 spaces. Postions 351 - 353 Text File Example: 105243 12 4101 00000000000009552 105243 12 4102 00000000000000325 105243 12 4108 00000000000043838 105243 12 4110 00000000000043838
I am getting the message "Module not found" after deleting a form that I no longer use...
(More)
I am getting the message "Module not found" after deleting a form that I no longer use anywhere in the database. If I put the form back - issue goes away. If I rename the form - comes back. Something is calling this form but I can't see what. Nothing references it in VBA, macro, query, etc. Where can I look next to see what is calling this thing?
