Fujitsu 18C1 Air Conditioner
Problem for Fujitsu 18C1 Air Conditioner
I am looking for the service manual for fujitsu 12rlq unit.
By dnk2 on Apr 08, 2009
I would like to check and verfy that our unit is properly charged. I have the pressure guages and R410A refrigerant and I am able to hook up to my outdoor unit but don't know the proper readings for servicing the outdoor unit. Any help finding service manuals or procedures would be appericated.
Dave K.
Solution #1
posted on Apr 08, 2009
Not Rated)
jumptrout51
Rank: Guru
Rating: 89%, 1023 votes
Low side pressure will be about 130 psig.
High side will be about 418 psig.
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 18C1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 18C1 Air Conditioner
Do you recommend Fujitsu 18C1 Air Conditioner?
Answer
Answer
unit will not turn even if manual switch is pressed on indoor unit
Answer
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries... (More)
Answer
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues... (More)
Answer
evap is blinking two green light flash and condensor will not operate on my fujitsu aou30clx split... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 18C1 Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
