Open up the door to the freezer, you will see two black switches upper right just above where the door would be when closed. Flip the first switch, then push the switch on the light in the fridge compartment and the light should go out. Thinking that switch is there to help reduce moisture inside fridge, just got pushed by mistake and light remains on. Hope this helps.
Ron1247
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Dometic NDR 1062 Refrigerator
Am attempting to calculate my power requirements while boondocking with my trailer. Can anyone tell...
(More)
Am attempting to calculate my power requirements while boondocking with my trailer. Can anyone tell me the amperage consumption of my Dometic NDR 1062 refrigerator while operating on propane? I also assume that there is a minimum voltage requirement? Cheers! Tom N.
I have Dometic 1062 Refrigerator/Freezer, The Cooling Unit will Cool if I install a jumper to the...
(More)
I have Dometic 1062 Refrigerator/Freezer, The Cooling Unit will Cool if I install a jumper to the 120 Volt Circuit; I also have the 12 Volts at Circuit board but it will not start electric heater or fire the gas unit even with the thermistor unplugged.I installed a new board which had several wiring revisions but I had similar results
two questions Dometic NDR1062 is there a heating element for the frig cooling fins, they have been...
(More)
two questions Dometic NDR1062 is there a heating element for the frig cooling fins, they have been icing up recently, new problem Ice make, quit, has electric and water. Pulled it out but unsure how to trouble shoot it. Replacement cost of whole unit? THanks Mike
set at auto, gas off and the propane check light comes on, unit won't cool. i turned the propane on...
(More)
set at auto, gas off and the propane check light comes on, unit won't cool. i turned the propane on after discovering and it took a while to light, but finally did. don't understand why it won't work on electric alone. this unit is less than one year old, and has previously worked with no issues.
