A/c hoping can get help few different things all revolving around the blasted a/c first whenever the a/c kicks in every light in the house dims for the initial boot up then good doesn't kick anything off just common sense says when it dims that much to everything else hoping nothings wrong ain't the best thing secondly looking at the a coils on the a/c unit model # c30a 054u on what I believe in an Intertherm unit also looking to clean the thing in hopes of helping to reduce the bill the a/c unit is constantly on moist on the lower half (moved in to home with family trying to help out) some of it did have dust caked on it so carefully removed the dust but week late not quite as much but still dusty. any suggestions on 1 how to prevent it for dimming the light when kicking on? and 2 the easier 1 how to safely clean it?
  • 1 more comment
  • tannim Sep 07, 2007
    model # actually is c3qa 054u b
    Thanks will look for the cleaning solution at local home depot or lowes (just easier sometimes) but with the lights it is all the lights in the house that dim when it kicks on and it only for the first ....2-5 seconds or less I know that the a/c is on a 20 amp breaker so will check the loads on both sides & see how well they balance just hoping not the compressor ain't got that kinda cash right know...
  • 1,420 Answers
The dimming of your lights at start up tell me two things, One is that the starting Amps may be a little high and drawing too much amperage. Have this checked by using an Amp meter. Secondly, look at your circuit breaker box. Does the Amp total on the right side of the box equal the left side. What I mean is that the Amp load of your box should be as close to equal as possible. If you have too many drawing Amps on one side, it puts strain on that side and will effect all breakers (loads) on that side. You can check this by investigating what circuits are on the same side of the box as your A/C unit and watch the lights associated to that same side and see if they dim when the unit starts. Also watch other lights associated to the opposite side and see if they dim. If they do, you have a compresser issue. To clean the coil you can purchase a coil cleaner at a local A/C repair shop and use a garden sprayer to apply. Rinse off the coil slowly and after you give it a chance to work. Too much water on the coil when rinsing will cause a flood in the bottom of the air handler and may not allow the drain to exacuate the water as quickly as designed. Rinse in moderation. Do this with all power off and the breaker locked in the off position.
Posted on Sep 07, 2007
2 Suggested Answers
  • 79 Answers
SOURCE: filters for a C30A-054U-B condenser
Hi!
Try going to a local sheet metal fabricating shop or a heating/air conditioning shop. They can probably make some up for you. Usually a lot less expensive than trying to order some from Trane/American Standard.
Posted on Jan 01, 2010
Lights dim
if the grinder just hums then it is a 240 volt unit and will burn out on 110 volts
the garage power should be the same as the house 240 v
but if only 110 v that indicates that it is 1/3 of a 3 phase power supply
if it has just started then get a electrician in to check the reason for the power drop
Jun 26, 2015 | Heating & Cooling
Why do lights flicker
An electric water heater will draw a lot of electricity. Your house may not be wired well, and when the heater kicks on, your lights will dim some. If your house is over 25 years old, it's likely normal.
Nov 02, 2014 | Rheem RTE 27 Tankless Electric Water...
THE LIGHTS IN OUR UPSTAIRS BATH HAVE STARTED TO SLOWLY FLICKER DIM AND BRIGHT, DIM AND BRIGHT.
Replace your breaker in the breaker box, and I wouldn't use these lights till its fixed. Kill the lights, kick the breaker to the off position This is the first thing that happens before an electrical house fire.
Dec 09, 2013 | Cars & Trucks
My dash lights dim out and when i high beam my cd player shut off and flash quickly then turn on. one day i was airing my tires at gas station and my dash light just dim out next thing is my car just died...
well,,, this could be a problem with your cars grounding.... so, here is some things to check out..
Is your battery cable connections clean?
Check the negitive cable to see that thair is a good connection to the engine (and)the body of your car..
next have you had your battery tested ? is it good?
next have you had the charginging system tested?
then look for bad or rusty or broken black wire connections under the dash and near the driver side kick pannels...
Hope this helps!
Sep 20, 2011 | 1990 Honda Civic
We just moved into a new house, and whenever I use
It sounds like it could be one of the following issues:
1. Bad wiring to the bathroom receptacle - this should be a GFCI outlet.
2. There is an overload somewhere on the same circuit - try the dryer with nothing else turned on.
3. The hair dryer may be bad or have a bad cord, plug, etc. Hair dryers can also become plugged (the air inlet screen) and overheat.
4. There could be loose or other bad wiring somewhere in the circuit.
If you are not familiar with working with electricity, it would be best to call a qualified electrician. They are the pros and can correct the problem.
May 20, 2010 | Kitchen Appliances - Others
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
How do atom the smallest particles of matter form
The current view is that atoms are made up of protons and neutrons (which in turn are made up of quarks and gluons) and electrons. The protons and neutrons are at the central core called the nucleus, and the electrons revolve around it, being held in orbit by the electromagnetic force between the negatively charged electrons and the positively charged protons in the central nucleus. It is very much like the solar system with the sun at the center and the planets revolving around it. They were formed right after the "Big Bang" when our known universe originated from pure energy some billions of years ago. The energy was converted to the elementary particles (quarks, gluons, leptons etc...) from which protons and neutrons were formed. From these, atoms of different elements were produced.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 08, 2009 | Lorenz Perko BATTERY SWITCH CABLE SPACER...
Yamaha Virago Cutting out in the wet
I had the same problem with mine. Its a dodgy ignition coil i found a spray of wd40 on it would fix it for a while by driving out the moisture. I've since put a piece of plastic bag around it which helps alot. Should really give in and buy a new coil though
Jun 19, 2009 | 2000 Yamaha XV 125 - S
Briefly explain the nature of the tech support job
basically it's helping people with similar problems that are posted on this website! However, different companies focus on different things are their set up is obviously different. Usually support revolves around helping using with their applications such as MS Office and configuring email. More advanced Tech Support Jobs would have you manage SQL server or install and configure system wide changes to Anti Virus, for example.
I hope this clears it up for you.
Dec 17, 2008 | Computers & Internet
Re: possible solution for the 9000 errors.
Ohhhhhhh yes,
Clean under and around the bobbin case regularly.....my wife has a small brush to hand, and does it at every bobbin change.
The quilters of the world need to be especially vigilant, as the wadding and layers generate lint at a remarkable pace.
As to bobbins, they do vary from brand to brand, diameter and height, so this can be an annoying apparently "intermittent" problem if you happen to have a few different brands kicking around.........I had one customer who had me on 3 house calls before I realised that she had been collecting blinkin' bobbins where and whenever !!
Another thing with the brown magnetic donut in the middle of your white hook race.........best to use Janome plastic bobbins to avoid any other troubles, rather than the older metal bobbins.
Glad it all went well.
Cheers
Martyn
www.bargainbox.com.au
Jun 10, 2008 | Janome Memory Craft 9000 Computerized...
Heating & Cooling Logo
1,095 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
