Question about Nokia 6080 Cellular Phone
Felt into water
My 6080 was fall in to water and I switch off it and open the mobile fully, cleaned with petrol and dried with hot air after that I assmbled and insert the sim card then switch on the mobile but the mobile screen shows "Insert SIM card" what can I do with this problem?
  • 490 Answers
Try by changing ur sim,,or ry in another handset,
Posted on Oct 23, 2007
6ya staff
SOURCE:
Samsung mobile sgh e840 fell into water
remove all possible [parts, battery, back cover, sim card, memory card and other things you can open using a special screw driver, let it dry several days or use a hair dryer on cool settings until determined everything is dry.
As for the battery, let is dry under the hot sun before attempting to put it back in the phone.
after that make a simple power on test, if it works, you are in luck, otherwise consider your phone completely water damaged and will not be accepted for repair due to the red water damage mark indicator.
Nov 25, 2013 | Computers & Internet
No power, even the battery is new and fully charge
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 18, 2011 | Cell Phones
The battery is fully charged but the phone does not turn on
1. Water damage
2. Fall down
May 24, 2011 | Samsung Cell Phones
How do I clean the vent filter for handheld leaf blower??
It will all depend on the material the filter is made out of. If you could post the brand and model, I could get a better idea. If you end up forcing air through it, be sure to blow the air OPPOSITE of its natural intake. You dont want to force dust further into the filter. Of course your safest course of action is to replace it if its really bad. I have seen (but will never recommend) people spraying carb cleaner into the felt filters, and then blowing air opposite of the natural intake(from the interior side). It gets felt filters extremely clean, but they will break down quickly. If it is a foam filter, detergent and hot water for a few min will work. Some foam filters need to be re-oiled (such as lawnmower filters) but I have never seen an oiled foam filter on a leaf blower.
Nov 21, 2010 | Garden
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
The clean light keeps blinking and won't run new cycle
Whirlpool & Kitchen-Aid
Tall Tub Dishwashers
PROBLEM: STOPPED RUNNING, WILL NOT START AND CLEAN LED BLINKS 7 TIMES, THEN REPEATS (WATER HEATING FAULT)
Control is programmed to stop running and not allow any further
cycles if it detects a water heating problem (no temperature
increase detected in heated Main Wash cycle or in 3 consecutive
cycles on the latest software version). Control blinks the Clean
LED 7 times repeatedly and disables the Start/Resume key until
cleared.
Running Diagnostics clears the control and allows it
to operate again. The water heating condition
must be corrected or the control will stop
running again. See potential causes below.
Check If…
Heater circuit problem:
♦ Open heater.
♦ Wire disconnected, open connection or component
in heater circuit.
♦ Faulty heater drive circuit on control.
Then…
1. Check operation of heater in Diagnostics cycle.
2. Unplug dishwasher or disconnect power.
3. Check resistance of heater and all components
and connections in the water heating circuit or heat
dry circuit.
Door switch not making contact consistently:
♦ Misaligned door latch assembly (which can be
aggravated by high door closure force keeping
strike plate from fully seating).
♦ Faulty door switch (high resistance).
♦ Loose or missing installation anchor screws,
causing tank to shift in cut-out.
NOTE: Neutral switch on plastic tub models is only in series with
the heater; other loads are not affected.
1. Unplug dishwasher or disconnect power.
2. Measure resistance of door switch contacts while
checking mechanical operation of latch assembly.
Confirm switches not loose from assembly. Check
strike plate and door closure.
Wash pump not pumping water past the heater efficiently.
• Foreign object in pump
• Excessive foaming
• Clogged pump screen or broken chopper screen
• Loose electrical connection in motor circuit
See Tech Sheet “WASH PUMP WILL NOT PUMP”.
Lack of water to heat. (Unit not filling properly)
• Insufficient water supply pressure
• Fill valve screen blocked or valve not opening fully
• Loose electrical connection on Fill Valve.
• Float switch obstructed or functioning abnormally
See Tech Sheet “WILL NOT FILL OR LOW
WATER”.
Diagnostic Key Dance:
Heat Dry - Normal - Heat Dry - Normal or
High Temp - Air Dry - High Temp - Air Dry
HOPE THIS HELP
Jan 24, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
I have bajaj boxer AT and I want to know How to clean its air filter
just take it out give it a rinse in petrol then let it dry out and then wash it in some hot soapy water and let it dry out and add airfilter oil if req thats it buddy
Sep 14, 2009 | 2005 Bajaj CT 100
My mobile is not being swith On
Make sure not to turn your mobile immediately
Dry your mobile first
Your could use blow dryer to remove get rid of the moist inside the mobile
then when you're sure that the mobile is already dry try turning it on
if the mobile doesn't turn on your mobile has already short circuited
Aug 21, 2009 | Motorola Cell Phones
Nokia 6080 Fell in water
It is stuffed, if it falls into water then the second it falls in it will short, and probably blow some critical components inside, even if the phone is off then there is always power running through it (so it knows when you are pressing the button to turn it on, also so it can remember the time and date)
May 24, 2009 | Nokia 6080 Cellular Phone
Nokia 6080 Cellular Phone Logo
140 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
