The top cleaned and locked, bottom locked and read that it is
unavaiable for cleaning .
Either BOTH cannot clean at the same time b/c they heat to 700deg and use alot of power, OR the 'Door secure' signal from the bottom oven is not getting to the controller. I suspect if that is the case, the switch is on the inside of the door, activated by the LOCK lever moving into locked position. It may be a beny switchlever, mis-adjusted LOCK lever or solenoid or disconnected wire.
If you leave the TOP open and force a clean, does the bottom lock and do nothing? (My other theory)
