Question about Kenwood KAC-859 Car Audio Amplifier
Power, but no sound
The power comes on . .but there is no sound coming out of the subs. It was working before, although i think i must have bridged it wrong or something . .because it stopped working . .the power light was going off, then on, then off, . . . .so i disconnected all the wires . . tried it again . .but the power now works . but still no sound. .i'm starting to think maybe it could be internal problem . maybe one of the mosfets, or something . .
    Genius:
  • 1,139 Answers
You may be correct. I would suggest that you get a schematic from the manufacture, and then using a voltmeter begin to test the test points of the final audio amp stage for bad voltage levels.
Posted on Sep 08, 2007
SOURCE:
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
Hello. I have one (1) XS-L1035 being powered by a JBL gts 180X 2/1 channel amp. The sub works fine if i power two(2) subs thru 2 channels BUT if I try to bridge the power to one sub the amp cuts out. Is it...
It sounds like the problem is with the amp. try using the other sub in bridged mode and see if it still turns it off. If it still turns off then its definitely the amp. In 2 channel mode you are using each channel at 4 ohms right? and in bridged mode to 1 speaker it should be throwing a ton of power on a 4 ohm load as well,it should work fine bro -its gotta be the amp
Jan 30, 2010 | Sony XS-L1035 Car Subwoofer
Protection light comes on
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Dou .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-comes-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Jun 14, 2009 | Nitro BMW-482 Car Audio Amplifier
Zx-8400 amp too much for zx-4812?
The amp and sub combo should work fine the subs can really take a crapload of power-i have a neighbor thats running 1200 watts rms to each sub in his caddy and OMG- its sick. Your amp should be pushing around 800 watts rms(continous) to the sub which should do very well-my concern with your setup is that the sub is designed for a vented box- you can use any box u want but im just suggesting that you use a good solid vented box with these subs- my other concern with your setup is that having only the single sub if its a dual coil 4ohm + 4ohm coils then you might run into trouble if you dont have it set up right-by that meaning to get all the power handling capability of the sub you would want to use both of the coils right? well to do that you have to either wire the coils in series or wire the coils in parallel right? In series the coils will yield an 8 ohm load to the amp and youll only get about 400 watts from the amp bridged into that 8 ohm load- on the other side of that if you wire the coils in parallel then the cols yield a 2 ohm load and that could cause the amplifier to become unstable and fry its little guts. All of this is assuming that the amp is made to run bridged at 4 ohms- if it is 2 ohm stable in bridged mode than you have nothing to worry about. Now the popping noise- that sounds like its coming from the amp somehow and just feeding through to the sub-like you ive never heard a sub popping unless its bottoming out and you say its not so its gotta be the amp id say-if it were me id check all power connections especially the ground for the amp . It could be that on the heavy bass notes that your amp is not getting enough juice -throw a 3.5 farad capacitor on the power line and see if that helps your system out-
May 22, 2009 | Volfenhag ZX-4812 Car Subwoofer
I have all the wires running right but for some reason my amp is not picking up or pushing my subs. could the rca jacks be messed up on the stereo?
According to the specs for the xo 1945- the output is; 50W x 4 Max Power Output , and I do not see a pre amp output listed. So I think to connect subs, you will need a separate AMP.
The way this works; the rear speaker wires from the xo 1945 hook into the Add-on amp, for example a 4 channel amp. In a 4 channel amp, the rear speakers come off two of the channels of the add-on, and the subs come off the other two channels. There is also the option of bridging two channels for more output power to ONE sub.
You did not mention what size sub(s) you were thinking of adding, but keep in mind that the ox 1945 puts 50 watts MAX per channel. So, if you add two 12" subs and a 1500 watt amp to drive them, your total sound is going to be very uneven.
If you go on line and look up auto audio or amps, you'll get a good idea of all the Sub and amp options that are available.... Hope this helps.
May 02, 2009 | Car Audio & Video
Subwoofers were said to be bad
overpowered definitely. when you bridge subs your almost doubling the power. if the subs were set for 2000 then the guy he took them too should have known better or at least turned the power down on the amp.
Mar 13, 2009 | Car Audio & Video
Left speaker channel not working
you may have to send it in or back to the company... being that its one side it could be a blown amp or perhaps a bad speaker on that side ..
hooking up two 6x9s and a sub in bridge mode you could have a wiring problem when i bridge an amp i go from positive of one side and negitive on the other to the same positive and negitive on the sub or box
` bridge =========== > SUB
hope this helps
Dec 25, 2008 | JBL GTO75.4 Car Audio Amplifier
Sub size
The sub you want is ONE single 4 ohm voice coil sub that is no higher than 500 watts in power but more than 350 watts. Your amplifier puts out the most power in the bridged state at 4 ohms so this is why you want a single 4 ohm voice coil sub. Also, you don't want to over or under power a sub so you want your sub to match or come close to your rated value of the amp. Good luck
-Andrew Hawkins
Sep 25, 2008 | Sony XM-1252GTR Car Audio Amplifier
Power
Have you checked the on-board fuses?
Did you confirm (with a multimeter) that you have voltage on the B+ and remote terminals of the amplifier?
Did you have the black meter lead on the ground terminal of the amp when you checked the voltage?
Jul 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Kenwood KAC-859 Car Audio Amplifier Logo
121 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
