Apex Digital AD1201 DVD Player Logo
A
Anonymous Posted on Aug 20, 2013
Code for apex dvd through rca universal remote
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Jul 06, 2008
SOURCE: lost code for universal remote
cherylchap,
This is an easy fix, you can go to the remote's manufacturer website and get a listing of all the codes.
Anonymous
  • 111 Answers
  • Posted on Apr 02, 2009
SOURCE: I lost my remote for APEX DVD player (AD-1000). How can I progrm
Buy a Universal remote Try "ONE FOR ALL" brand..
Quickfx PC Repair
  • 846 Answers
  • Posted on May 20, 2009
SOURCE: need remote control for my Apex Digital DVD player (model 1110W)
DVD remotes typically have 2 sets of up and down arrows for such things. Make sure the remote you purchase is meant for dvd players.
There really isn't anywhere to search for what remote would work perfect for you other than some very costly ones. So I can't really point you in the direction of a make or model.
You can also Email Apex Support and ask them for a replacment remote. It will cost you but no more than a normal remote and its made for your dvd player.
Thank you for stopping by Fixya!
Anonymous
  • Posted on Dec 06, 2009
SOURCE: code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Anonymous
  • 185 Answers
  • Posted on Mar 23, 2011
SOURCE: i have dish network and
Try the steps below these processes are called a power scans, there is a different type for any equipment needed. This should take 5-6 minutes per item to program.
For DVD/VCR's:
1.) Press and hold the correct VCR/DVD button (about six seconds) until all mode button backlights come on, then release.
2.) Press 222 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
For TV's:
POWER SCAN
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
For any other equipment:
Power Scan AUX
1.) With the desired equipment on, press and hold the correct AUX button until all mode button backlights illuminate (about 3 seconds), then release.
2.) press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
Press and release the large red Power button.
3.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
With any of these methods verify the code works by trying several different functions for that equipment.
Daniel Busa
DISH Network
Customer Service
Codes for apex dvd on RCA universal remote
U get those codes, if any, from the manufacturer of the universal remote.
3helpful
2answers
Apex codes
Hello
You are seeking codes with RCA systemlink-3 remote control to Apex TV. Unfortunately, there is no setup codes for Apex Tv with this remote control. It is very difficult to gat a remote control that has setup codes for Apex Tv.
Comcast On demand custom-3 universal remote control has codes for Apex.
Codes are :
0748, 0765, 0767
OK.
Need remote code for Apex AD-1201 DVD player w/Comcast universal remote (red OK button, black Comcast letters)
I don't have the original control remote for Apex Ad-1201 DVD player. I would like to use my Universal Remotes: Radio-shack USA "flag" 4-IN-ONE Remote and / or RCA 312W three component remote. I got the codes from the manuals but my DVD player doesn't work or turn off (only ejecting; open and close) with pause button. Could I get a possible code (s) for these Universal Remotes?
I have lost my remote to my APEX AD 1225 DVD player so I bought a cheap RCA universal remote and the codes are not working for my player. The remote is RCR311BI. What code would work?
I am very happy to help you reprogram your RCA RCR311B for your Apex DVD player.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up on this remotes device code list.
I hope that helps.
2answers
How to enter code on the remote
Hello Comtoist.
Here is a link below which talks you through the process. It also has tv codes etc for you as well In case you did not have them
http://www.universal-remote.net/rca.html
Hope this has sorted you out. If so then please leave a thumbs up
Cheers
Little Dish Fitter
2answers
Need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
Uplate
code are usually universal what ever is the device you are trying to connect. you just need to know the code of the device: ex here an apex device. however, can you be specific on the device. is it a tv, dvd, vcr etc.?
Remote codes
I need remote cod for my rca remote just like the one you had pictured on this page,my tv is a SANSUI
My e-mail is [email protected]
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
