Question about Samsung PCH521R 52" Rear Projection Television
Samsung tantus oct. 1998 pch521r
Red lines straight thru. I can see the picture still
  • 2 more comments
  • sexylb Sep 08, 2007
    How do you turn down the screen control?
    I think it's lcd
    yes, Oct, 1998
  • sexylb Sep 13, 2007
    When i get home this weekend, i will open up my tv. Wish me luck
    Sergeant:
    Champion:
  • 375 Answers
Screen control must be turned down ,called retrace lines
Posted on Sep 07, 2007
  • 1 more comment
  • Anonymous Sep 08, 2007
    is your set lcd or crt projection set if crt projection remove front grill and you'll see the focus block assy. there are 6 controls on it marked screen and focus and labled r/g/b/
    do you have three picture tube in the unit ,if yes it rear projection unly and you can use the set up for crt's screen adjustmint/is this set a 1998 model look on the rear panel for mfg. date.
  • Anonymous Sep 09, 2007
    remove front panel assy, you'll see a black focus block with 6 adjustments on it 3 are focus 3 aer for screen and are marked turn the red one way slowly then reverse until your retace lines are gone.
SOURCE:
My samsung tantus shows picture but no sound
there is "audio out" jacks on back side of television. connect it to an amplifier or other tv & hear if sound is comming. if sound is comming then audio amplifier is defective in your tv. if sound is not comming then audio processor may be defective.
Aug 30, 2011 | Samsung PCH521R 52" Rear Projection...
Samsung tantus blinking red light
you need to general service the whole unit. this will include re-soldering and changing some defective components from the board, which has been damaged through using from past years. my advice is to have a quotation from service tech and then think about repairing it..if it is better to buy a new one..
Nov 16, 2009 | Samsung PCH521R 52" Rear Projection...
Television will not turn on
you wiull have to check it with a meter if its getting short the meter will show zero reading other wise the faulty low reading.if thats the case the part has to be replaced. you can get the required parts at www.radioshack.com or at  www.partstore.com
Feb 26, 2009 | Samsung PCH521R 52" Rear Projection...
Samsung Tantus problem
your main power supply is gone out
Aug 30, 2008 | Samsung PCH521R 52" Rear Projection...
Convergence is completely messed up and Audio drops
can someone tell me how to fix the convergence the red and the blue are messed up and the picture perfect doesnt work.
May 27, 2008 | Samsung PCH521R 52" Rear Projection...
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
Samsung 52" tantus pch521r no picture
1) Loss of color = bad solder connects on signal board
2) Loss of pix = probable CRT coolant leak onto signal board
Have a technician check it out.....can be expensive......T.
Nov 24, 2007 | Samsung PCH521R 52" Rear Projection...
Samsung PCH521R 52" Rear Projection Television Logo
146 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
