Question about Compaq iPAQ Connection Point CP-2W (241274-001) 802.11b Wireless Access Point
Weak/No signal My CP works fine as a router, but the wireless signal is intermitten. It's weak when it is recognized by my laptop, but usually drops off after a few minutes. During the time when the signal is weak, I still can't connect to it. I saw in a "Best Solution" that you would post the answer if the problem had not been resolved.
  • Charles Carlton Sep 12, 2007
    I searched every possible option on the administration web pages, then downloaded the manual and search it as well. There is no visible (or documented) way to change the "transmit power" for the access point. I also looked for anything the seemed like it could be related, with no luck.
    Any additional suggestions would be greatly appreciated.
    Sergeant:
  • 274 Answers
Opening your browser. Looking in your manual there is an instruction telling you how to connect directly with your modem. Type that address in, enter the user name and password it tells you. Then look through several of the option tabs it will display. There will be one that controls the "transmit power" level. Once you find it, change it to 100% if it something less than that. That should fix your problem.
Posted on Sep 09, 2007
My laptop is in the living room, my 2WIRE router in the bedroom. When I turn on the MAC it sometimes indicates that I am not connected to the Internet. I then have to fool around with diagnostics to try...
I would boost the signal it can only help I had the same sort of problems but my wireless router quit working properly my iPad wouldn't pick up signal so I had to replace my wireless router hope this helps Merry Christmas
Dec 09, 2017 | 2wire Wireless-G 802.11g ADSL Gateway
Computer keeps dropping signal and now doesnt recognize signal
how far is your computer to the DSL wireless router? If it is too far and signal becomes to weak you won't be able to connect. And also make sure that there is no metal, concrete wall in between, it will block signal too. Good luck Thanks
Aug 15, 2011 | Linksys WRT160N Wireless Router
Signal drops
You may need to update your computer drivers or check antennas on router - probably wireless card getting weak in laptop
Jun 29, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Router keeps dropping and weak signal. was great
Change Wireless Channel to 7 or 12.
After that restart your router.
Your problem will be resolved
Mar 04, 2010 | Linksys WRT300N Wireless Router
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Linksys wireless b router
Weak signal problem can be fixed by firmware update however, if the client computer is too far from the router, it can't be helped. What you need is a wireless range expander. What it does is give you another 100% signal or atleast stronger signal to the spot or area where you have a weak or dead signal.
Jun 29, 2009 | Linksys Wireless-G Broadband Router
Computer will not connect to wireless router
the antenna wire sounds pinched it is in the usually in the lid and can be found by looking in the hinge area
Look to see if it is kinked
LB
Sep 21, 2008 | ASUS Eee PC 900 16G Notebook
Check the wireless network card
try to reinstall the driver
Jul 27, 2008 | Computers & Internet
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
See all Compaq iPAQ Connection Point CP-2W (241274-001) Questions
Compaq iPAQ Connection Point CP-2W (241274-001) 802.11b Wireless Access Point Logo
104 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
