Question about Panduit LS7 THERMA TRANS Thermal Label Printer
Panduit ls8e application error - Panduit LS7 THERMA TRANS Thermal Label Printer
How do I stop my printer from skipping a blank row of labels in between each row I print?
I was using LibreOffice Writer to print terminal block labels on my TDP43MY and was having all kinds of problems. (I tried EasyMark too, but had just as many problems.) The printer was constantly switching landscape and portrait modes on me. It would print 2 sets of good labels (portrait) and then the next label would be landscape. It did this no matter if I printed one page at a time or if I printed the whole document. I spent over half a day trying to get it to work, and finally succeeded - read on.
No surprise that the Panduit TDP43MY printer is really a Zebra printer. I discovered this by accident when I first got the printer. I connected it without first installing the driver and windows asked for a driver for a Zebra printer. Knowing it was a Panduit, I rejected windows offer and installed the Panduit driver. I spent a whole day trying to get it to print correctly and decided I would try windows recommendation of a Zebra driver. I did some digging and discovered it is a Zebra TLP 3842 printer. I removed the Panduit driver and installed the Zebra TLP 3842 driver. The version I have says "Windows driver for ZDesigner TLP 3842 Version 5.1.07.6290 Copyright 2016". I then used LibreOffice Writer to print my labels again. Wonder of wonders it printed with ZERO problems! Yeah for Zebra!
May 06, 2014 | Panduit TDP43MY Thermal Label Printer
Wiring CJ688TGBU
Try to search on the Panduit-Website. For most products you can download a pdf with instructions.
Nov 12, 2013 | Panduit CAT6 TX-6 8P8W MODULE BLUE ...
Panduit printer tdp43my wont print
There are lots of possible problems here: printer broken, bad cable to computer, bad roll of ribbon, labels don't match ribbon. I was having problems getting my TDP43MY to print correctly. I ended up removing the Panduit driver for the TDP43MY and installing the Zebra driver for the TLP 3842 instead. Turns out Zebra makes this printer. The Zebra driver worked much better for me. If you think everything else is fine (printer OK, cable OK, etc.) you might try installing the Zebra driver and see if that helps.
Oct 01, 2013 | Panduit TDP43MY Thermal Label Printer
I have a LS8EQ printer, I am receiving a message reading "exception trap" then the printer turns off. I am using .38mmX7.6m tape. It only displays this error when using font size 10, but it will print...
If you are using an imported file, file names must be under 8 characters and have no spaces. Please be sure to delete the converted .DAT file, rename the original .CSV according to these rules, then convert the .CSV to .DAT.
Sep 06, 2013 | Panduit PanTher LS8E-KIT Hand-Held Thermal...
Why i can't reach the printer on Panduit easy-mark software
I have to power up the Printer and then reset my PC, before seeing my wireless printer.
Mar 26, 2013 | Panduit Easy-Mark Labeling Software...
Where can I get LS7-75NL-1 label tape?
I am also looking for a tape cassette (LS7-38-1) for the LS7 label printer, and cannot find one anywhere. I called Panduit and they said the LS7 has been obsolete for several years, and they have no tape cassettes for it.
Feb 18, 2013 | Panduit LS7 THERMA TRANS Thermal Label...
Panduit mini-com tx6 cjs688tgy how can punch cable and what is the color coding
The colours refer to the (usually) colored pairs of wire in a Cat5, 6 or 7 cable. There are two schemes called 568A and 568B, where some wire are different. Since these jacks are used for permanent wiring, you can choose one of the schemes and use it at both sides of the cable. Watch out if someone has already installed network-cables in the same building and use the same scheme!
You dont need to "punch" the wires. This old method (LSA+) is not good enough, if you have very high bitrates, like we use today. Go to the panduit-website and download a data-sheet of your jack - it should include wiring directions.
hth, Karl
Oct 18, 2011 | Panduit Mini-Com TX-6 Plus (cj688tpor)
Looks like you need a 110 punch down tool. I would get a spring loaded one that cuts the cable automatically. It is truly the only way to go with terminations.
May 16, 2008 | Panduit Mini-Com TX-6 Plus (cj688tpor)
Viper LS6
cable serial de pc a viper panduit LS6 o como lo puedo hacer la conexion
Mar 06, 2008 | Panduit VIPER LS6 Thermal Label Printer
Panduit LS7 THERMA TRANS Thermal Label Printer Logo
1,159 people viewed this question
Top Panduit Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Panduit Office Equipment and Supply Expert? Answer questions, earn points and help others
