I have experienced that not only when the thermal cut off fails it's quite often that the high limit switch is the cause and suggest replacing both at the same time. These switches are notorious for failing in series. Also a blocked vent can cause a build up in chamber causing a "detected fault" which can cause this sort of problem also. Be sure that your venting is sufficient and that there is not obstruction or kinking in vent stack.
SOURCE: no heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
SOURCE: my kemore dryer model 11071812001 not drying clothes
you may also want to check the igniter. This maybe heating on inital start then shorting when it tries to restart. easy to troubleshoot..let me know [email protected]
Might be the timer. Might just need cleaning. Take a look at my home video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
