Question about ViewSonic VX910 19" LCD Monitor
Monitor blacking out intermittently
The monitor is blacking out intermittently, the green power light is blinking when this happens. Sometimes it comes back if I unplg the monitor from the wall, other times it doesn't. The last time this happenend (tonight) it would not come back at all.
  • Anonymous Mar 09, 2009
    - HP L1506 LCD goes black after several hours and stays black until power plug is removed and reinserted. Now LCD goes black within 10 seconds after power is applied. Sometimes front panel green LED flashes like a heartbeat (defective electronics?) Unit was Manufactured July 2006.
    - VGA cable exchanged with known good cable with no effect.
    - Unable to call up OSD menu before unit goes black (LAMP issue?).
  • 159 Answers
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
  • 2,022 Answers
It is monitor power problem pls change the power cord and see. bye
Posted on Sep 24, 2007
  • 69 Answers
The problem lies within the DVi or VGA cable. If you bump the cable, or if it is not securly in place at one end, or the pins are broken, the picture won't be displayed correctly, Check to make srue both ends ae intact and plugged in securely, and if it still happens, buy a new DVI/VGA cable . That will solve the problem. It also explains why the light stays on. There is an external power source(the wall outlet) powering the moniter, but the video cable is not working and isn't transmitting the picture.
LG M197WDP, used as a monitor with a Windows 7 computer. Intermittently the monitor goes black for 15 to 20 seconds then the picture returns. I have checked drivers etc all up to date. Anyone able to
Could be a hardware issue, If the screen has a power light, does it change coulor (often green to orange) when the problem happens. If so its the screen inst getting any signal. It could be a connector or cable.
Nov 01, 2014 | Computers & Internet
L246WH blinking light problem
Probably the power supply is failing but periodically recovers briefly.
Jan 05, 2014 | LG L246WH-BN Monitor
Monitor black but power light blink green
The 470uF 25 Volts capacitors on the power supply board are probably bad. Replace them all and tell us the result !
Feb 24, 2010 | Hannstar I-Inc TW-191D Monitor
Power light blinks red, green and off. No picture
Is there another monitor input on the back of you computer? Sometimes this happens when your graphics card is not compatible so it is best to try another one. If you have another one plug it in there first. If you don't try the monitor on a friends computer. If it still does the same thing, it may be a manufacturer defect and may need repair.
Nov 06, 2009 | Planar PL1911M-BK (Black) 19" LCD Monitor
Dell LCD Monor light keeps blinking green, screen is black cannot stop blinking unless unplugged from power source but upon plugging back in monitor starts blinking green again
Your monitor has a bad power supply board. This happens often on LCD monitors because of the heat buildup in them. If you can solder them go to our web site at: We have a step by step dis-assembly and repair guide for your monitor. There are several versions of the E173FP some end in b , f, or c so be sure to check your monitor.
I hope this helps, if so please rate my solution.
Corporate Computer
Aug 27, 2009 | Dell E173FP 17" LCD Monitor
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
goo dluck if you want it fixed for you let me know
Mar 22, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
1,627 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
