Question about Philips GoGear SA178 MP3 Player
Philips GoGear memory error
Hi, I have a Philips GoGear 512mb. not sure of the model i'm using. When i plugin thro USb. the device gets detected, but the drive is not displayed in the 'My computer'. After i Plug out the device it says ' MEMOER FORMAT ERROR ', Guys pls help me fix this problem. Thanks. Regards, Mahesh.
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Philips go gear sa3245/97 not starting
You can download content to a Philips GoGear multimedia player using Windows Media Player or MusicMatch Jukebox in Windows. Earlier versions of Windows starting with 2000/ME and XP are compatible with GoGear. If the device is not recognized by the Windows XP operating system or is receiving error messages, you may have older versions of the necessary software installed. There also may be firmware issues with the GoGear device.
Instructions
Connect the Philips GoGear to another USB port on the computer. Sometimes USB ports go out, especially those in the front of the computer case. Try inserting the GoGear into another port and see if XP can now recognize the device.
Download Service Pack 1 or later for the XP operating system (see Resources). Philips GoGear can only operate on XP systems with at least Service Pack 1 installed. You may also receive an error message pertaining to the service pack when trying to insert the installation disc for the GoGear support software.
Install the latest version of Windows Media Player. Philips GoGear requires at least Windows Media Player 11. Windows Media Player 11 is available for XP .
Install the latest version of MusicMatch Jukebox (see Resources). Earlier version of this software may be causing error messages regarding missing MP3 tag information and missing tracks. Follow the download prompts, then unzip the folder and click on the "HDD_xxx.exe" installation file. The latest version of the software will be installed.
Install the latest firmware on the Philips GoGear. The actual firmware required depends on your GoGear model. Open either Philips Device Manager or Songbird, depending upon which management software you are currently using. Close all programs on the computer except for the Device Manager/Songbird. Connect the GoGear to the power supply and the computer. Click the "Repair" tab in the Device Manager and click "Repair," or click "Tools" in Songbird and select "Check for updated firmware," and the firmware will be updated on the GoGear.
Mar 31, 2011 | Philips Audio Players & Recorders
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
Getting an error message on my Philips Gogear OPUS 16GB player " Wait for usb connection, cannot find the data file!'' Not sure how to rectify this problem! Please help!
Here is a link where you find the user manual of your device:
http://download.p4c.philips.com/files/s/sa5295_02/sa5295_02_dfu_eng.pdf
Read it's content in the page 44. I think it is necessary to update of your player and I hope you can repair it this way.
gylacz
Mar 07, 2011 | Philips GoGear SA5285/37 Digital Media...
My GO gear Mp3 player wont be detected on any computer. even if you install the hardware, it wont still detect.
if your player don't detect . also don't detect with Philips Device Manager
try to download this driver for it usb 2.0 ADFU Driver .
i worked with 7 and in system device manager show "uknown usb device" but in XP show this "usb 2.0 ADFU Drive" and also the Xp itself install it . if your windows dosent have this so go on to download it manualy . then use philips device manager to repair it . i do it myself and it worked
Dec 13, 2010 | Philips GOGEAR SA6045 MP3 Player
I am using philips gogear 2gb mp3 player, the problem is, the mp3 player is fully charged by an external usb charger but still it doesnt turn on. i heard that restoring to factory default setting would...
well i guess the device manager provided by Philips is a little bit crappy..personally, i tried several times with my device and it didnt recognize my device at all. until i tried to call the support centre, they provide me the solution. it s all abt the steps in doing the repair.
1) open device manager
2) press the vol key (mine is the vol key, i know this varies from models to models, maybe you have to check) and dont switch on the device --
Aug 07, 2010 | Philips GoGear HDD075/17 MP3 Player
FROZEN On NON SUPPORTED FORMAT DETECTED SCREEN
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently. Actually, don't go to Philips website - run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect it to the computer until a Found New Hardware Wizard window pops up. Once all this is done, use the Philips Media converter to convert all your video files from now on.
-Tha Mp3 Doctor
Dec 08, 2008 | Philips GoGear SA5285/37 Digital Media...
I'm not sure about the Memory Format Error, but you are going to need the software to not only recharge the player, but put music on it as well. To turn it on you have to hold down the play button until you see a little "Philips" logo pop up on it. I looked into downloading the upgrade to see if it could recharge that way, but it seems to be only what it says it is; an upgrade. I suggest you ask your husband's friend for the software disk.
Sep 19, 2007 | Philips GoGear SA178 MP3 Player
HDD6330 file structure issue
First, reload the CD. Then grab a clean version of the software from the Philips website: Then,
-Tha Mp3 Doctor
Sep 16, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GoGear SA178 MP3 Player Logo
308 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
