Question about Jenn-Air JMC8130DD Microwave Oven
Oven combo, oven works but the micro has no power
While oven was cooling from a marathon baking session, the micro was used to warm food, worked for a little while before it died, no pwer at all, the oven is functioning okay, can you tell me where the fuse/breaker/reset is located on the unit, its a jennair jmc8130dds combom unit.
  • 3 more comments
  • pneary Nov 24, 2007
    Same problem. Repairman will be here Wednesday. What a disaster for Thanksgiving!
    Lake Tahoe Pat
  • JimK12345 Nov 30, 2007
    I was running the oven through a cleaning cycle and tried to heat up lunch in the microwave. It ran for a little bit, then died completely. No display, no light inside, nada. Everything has cooled back down, but still no working microwave. Oven seems to be fine.
  • jbonett Dec 04, 2007
    Having same problem.... Microwave went blank while heating vegetables... not overheated, nothing unussual about the usage. The oven still worked fine. I contacted a repairman. He came and said it had fliped the circuit breaker on the unit (not the one in the basement). He said that he simply pulled it out and flipped the circuit breaker, everything worked for about 2 weeks.... then it happened again! I tried removing the screws to pull the unit out and couldn't figure out how to detach it from it's oven below???? Very confused - we have had the unit for 4 years with no issues. Can anybody else tell me how to reset the circuit on the unit?
  • dyinmicro Dec 08, 2007
    exact same problem. micro display died within a week of purchase, oven is fine. called sears service, but the darn thing came back alive 2 days later (before the service guy arrived!). of course it works fine thru the service call and decides to die again the next morning!. service guy had nothing to offer for possible root cause - kept saying something about the on-board computer in the micro can decide to shutdown for unknown reasons. i am close to dumping this back at sears and pick something else. service guy expected early next week. will keep you all posted as this drama unfolds!
  • macoodilali Jan 01, 2009
    Also have a Jenn Air JMC8130DD microwave that stopped working. Went to use it, and it flashed once and went dead. First tried the circuit breaker, but that was fine. Called a repairman and he pulled the entire unit out and finally said that we needed a new "power control board" and a new "panel control", would run around $500. This unit is only 2years old and have not had any problems, except it was making an unusual sound when opening the front door; sounded like it was rubbing or catching on something. When the unit went dead and I opened the door, this sound was no longer there. We also live in an area where we have a lot of power surges and the repairman said that could have been part of what caused the problem. Being a single woman, in an area with limited repairmen, I'm not certain what to believe. Also not certain if I should have parts replaced for $500 or buy a new one altogether for $1300. Any input or information would be greatly appreciated
The fix for my problem was to remove the oven/microwave combo unit, and press the reset button on the back of the microwave. Oh yeah, and to write a $75 check for a 10 minute service call.
You want to try the fix for yourself? You have to remove all of the face screws holding the unit in place. There are 4 on the microwave front and 6 in the oven, 3 down each side, inside the lip where the door is. You must remove the door to get to the bottom ones. You don't have to remove the screws holding the plastic insert in place between the micro & oven, but you might want to remove the metal lip on the bottom of the oven to help prevent scratches to the cabinet. After that's done, get a helper and pull the unit most of the way out, then rotate a little to the left. That will expose the reset button on the back, right side of the microwave.
Posted on Dec 26, 2007
We (it will take two of you unless you are Godzilla AND you can tie the oven door shut) were able to slide the whole unit out just enouth to be able to tip it forward just enough to reach the cord from the microware and the switch next to the outlet on the top of the oven. In our case there are extra 110v outlets in the cabinet cavity so we plugged the microwave into on of the new 110v outlets and hope to not have this problem again. My thanks to all who contribute here because without your insight I would have called the repair man and spent $$$ I don't have. Thank you.
Posted on Nov 29, 2008
Whatever
Posted on Sep 24, 2008
MINE DID THE SAME THING I JUST GOT DONE PULLING IT OUT AND RESETTING IT WORKS FOR NOW. WHAT A **** POOR DESIGN, THINK I WILL SEND A E MAIL TO JENNAIR AND TELL THEM HOW MUCH OF A JOKE I THINK THERE PRODUCT IS. Hell i paid 59.00 for a microwave that lasted 17 years.NOT HAPPY, thanks to all
Posted on Aug 11, 2008
When you have the unit out of the wall to reset the breaker, take the microwave power cord and slightly bend the flat prongs out so that it makes better contact in the outlet. That should solve the problem once and for all. Mine started tripping the breaker and got so bad that it would not operate for more than a minute at a time.
Posted on Aug 09, 2008
We finally got this fixed (been more than 6 weeks and the problem has not surfaced). the fix was replacing the power supply plug. it was not a snug fit with the female in the back of the oven. alternate fix could have been plugging the power supply directly into a wall socket.
Posted on Jan 29, 2008
Confirming what Jimk12345 and whirlpoolbad have posted. On the microwave / oven combo, there is a circuit breaker on top of the oven in the back next to a 110v outlet that the microwave plugs into. Our tripped during oven cleaning when the microwave was used to heat a dish. The only way to access the reset (other than going through the wall) is to slide the oven and microwave out far enough that you can reach in behind the microwave and reset the 20 amp breaker. Of course onle do this after everything has cooled down!
Not sure what idiot designed this, but it certainly was NOT an engineer.
    Problem Solver:
  • 5 Answers
Just confirming what JimK12345 experienced is exactly what fixed my problem. Why Jenn-Air/Whirlpool will not acknowledge this design flaw nor disclose this simple solution is beyond me.
I would suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Posted on Jan 04, 2008
My solution is similar to JimK12345 but my problem was described as an "on/off" switch on top of the lower oven below the microwave. My first check was for $118.00. It went to the repair service guy covered by the warranty (the unit had only been in for 5 months). Repair guy determined that the problem was electrical as everything checked out okay and advised me to call an electrician. As electrical problems are not covered by the warranty, I had to write the guy a $118.00 check for his time. (The warranty repair guy is not authorized by by Maytag/JennAir/Whirlpool to unscrew the unit, remove the door and look behind the stove).
I then called the contractor who installed the unit during our recent remodel. ( I called repair guy first because, after all, the unit was under warranty. I knew the electricity was fine because the oven was working, so common sense told me it must be a problem with the microwave). It turns out there is a switch on the top of the lower oven below the microwave that, for some reason, must allow a person to turn the microwave portion off, leaving only the lower oven operational. This switch had gone from "on" to "off" - evidentally as a result of vibration during the cleaning process when the microwave was started. I wrote another check for $100.00 to the guy who installed the oven. $218.00 later - and 10 days later - I was back in business. I called the repair guy to let him know what the problem had been, and he didn't know why the switch was there - but said the impractical engineering on the JennAir caused some strange problems at times...
It's important to know that, if this is your problem you will be paying two repair people if you are under warranty. I am curious to know if this was the solution for many of you with this problem. Hope it helps.
AEG micro-combi oven has big condensation problems. The glass on the oven door clouds over and drips of water can be seen on the glass. Water also drips out on both sides of the oven at times formin
Condensation inside the oven comes mainly when the temperature is below 100 Celsius, and this phenomenon is evident in almost all manufacturers. That means, the condensation starts at the beginning and at end of baking. My advice is the same as many manufacturers recommend: Before baking, preheat the oven to min. 100 Celsius and after that place the food in the oven. Reverse the procedure in the "cool down" phase before the temperature drops below 100 ° C and remove the food from the oven.
After that condensation should be drastically reduced.
Condensation could be technically solved but it would be too expensive for manufacturers (more parts inside oven) as well as for customers also (too expensive appliance and lost energy).
Dado
PS. This applies to the traditional way of baking
Feb 14, 2015 | AEG Microwave Ovens
My microwave doesnt work
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Thanks,
micro
pls. rate..
Mar 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Tip
Microwaves and how they work. ­T­he microwave oven is one of the...
Caption
--> ­T­he microwave oven is one of the great inventions of the 20th century -- millions of homes in America have one. Just think about how many times you use a microwave every day:
Caption
­You're running late for work, so there's no time to fix breakfast at home. On your way to the office, you stop to gas up your car. Inside the quickie-mart, you grab a frozen breakfast burrito and pop it in the microwave on the counter. Later that day, you have to work through lunch. By 3:00 p.m., you're starving, so you grab a snack-pa­ck of microwaveable popcorn from the vending machine and pop that in the break-room microwave. That night, after a really long day at work, you're simply too tired to grill out, so you dish up last night's lasagna and heat it up in the microwave...
As you can see, microwave ovens are popular because they cook food in an amazingly short amount of time. They are also extremely efficient in their use of electricity because a microwave oven heats only the food -- and nothing else. In this article, we'll discuss the mystery behind the magic of "meals in a minute" with microwave cooking.
­A m­icrowave oven uses microwaves to heat food. Microwaves are radio waves. In the case of microwave ovens, the commonly used radio wave frequency is roughly 2,500 megahertz (2.5 gigahertz). Radio waves in this frequency range have an interesting property: they are absorbed by water, fats and sugars. When they are absorbed they are converted directly into atomic motion -- heat. Microwaves in this frequency range have another interesting property: they are not absorbed by most plastics, glass or ceramics. Metal reflects microwaves, which is why metal pans do not work well in a microwave oven.
Microwave cooking ­You often hear that microwave ovens cook food "From the inside out." What does that mean? Here's an explanation to help make sense of microwave cooking.
Let's say you want to bake a cake in a conventional oven. Normally you would bake a cake at 350 degrees F or so, but let's say you accidentally set the oven at 600 degrees instead of 350. What is going to happen is that the outside of the cake will burn before the inside even gets warm. In a conventional oven, the heat has to migrate (by conduction) from the outside of the food toward the middle. You also have dry, hot air on the outside of the food evaporating moisture. So the outside can be crispy and brown (for example, bread forms a crust) while the inside is moist.
In microwave cooking, the radio waves penetrate the food and excite water and fat molecules pretty much evenly throughout the food. No heat has to migrate toward the interior by conduction. There is heat everywhere all at once because the molecules are all excited together. There are limits, of course. Radio waves penetrate unevenly in thick pieces of food (they don't make it all the way to the middle), and there are also "hot spots" caused by wave interference, but you get the idea. The whole heating process is different because you are "exciting atoms" rather than "conducting heat."
In a microwave oven, the air in the oven is at room temperature, so there is no way to form a crust. That is why microwavable pastries sometimes come with a little sleeve made out of foil and cardboard. You put the food in the sleeve and then microwave it. The sleeve reacts to microwave energy by becoming very hot. This exterior heat lets the crust become crispy as it would in a conventional oven.
on May 07, 2010 | Microwave Ovens
The oven occasionally burns the bottom of food--it happens early in the baking process--what am I doing wrong? Cheryl
Make sure that the dishes you are baking in are approved for microwave use. Try running the oven at lower power if it is adjustable on this machine. It's possible that the 'stirrer' ( a fan like device) in the microwave waveguide (sheet metal tube between the magnetron and the cooking cavity) is not spinning for some reason. The cooling air from the magnetron flows through the waveguide and is supposed to spin the stirrer. Probably best to contact an appliance servicer to check this. Hope this helps!
Oct 02, 2010 | Microwave Ovens
I warmed up a cup of coffee in our microwave then
This usually means that the magnetron circuit has failed. The magnetron is the part that generates the microwaves to heat the food. Typically the problem is the magnetron itself that has died. The cost of replacement comes close if not more than a new microwave oven. Unless the oven is still under warranty, it not worth fixing.
Feb 14, 2010 | Sharp Microwave Ovens
Can i bake cookies on my sharp carousel with bake setting. can i use an ordinary micro safe plate or do I need something else?
yes you can bake cookies in the carousel on BAKE I suggest those new rubber looking bake plates help a lot to reduce the moisture that makes them soft.
I think they are silicone rather than rubber, i am sure you know the ones I mean
Thanks for using FIXYA
Oct 11, 2009 | Sharp R-1850A Convection/Microwave Oven
Microwave is just over 1 year old and has stopped heating things
Most micro's have a % heat setting. Make sure that you are at 100%
Jul 21, 2009 | Microwave Ovens
Wont heat
Hi!
Here are two instances when this happens---
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Microwave's Power goes off after 3 minutes running..
If the time from START to shut off were EXACTLY 3 minutes, then I would suspect a sensor problem or corrupted code in the microprocesor. But since that time sounds more random, it sounds heat-related, and I would suspect a failing magnetron or a failure in the cooling system. If the cooling fan is not running while the oven is cooking, this failure can occur, and can destroy the magnetron in short order. A cracked magnet (has the oven been dropped?) or other problem can cause a magnetron to go bad and overheat. If it's under warranty, I would definitely contact the manufacturer (see your manual) to find an authorized local servicer. If it's out of warranty, I would balance the cost of a new microwave versus a bench diagnosis fee of $25 or more or an in-shop repair cost of maybe $80 or more.
Oct 15, 2006 | Westinghouse WST3504 Microwave Oven
Jenn-Air JMC8130DD Microwave Oven Logo
370 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
