Question about Mitsubishi WS-65807 65" Rear Projection Television
Power on won't stay on
I turned the power on and the green light comes on and then it goes off within three seconds. I tried it over and over again but it won't stay on.
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Posted on Sep 07, 2007
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony KDL46V2000 TV. Screen comes on and goes off in continuous cycle
you have a leaking cap on your power supply /open up and check on just replace those caps that looks swollen
Nov 16, 2017 | Sony KDL-46V2000 46 in. LCD Television
Pushing on power button three green lights come on for one secone
click here you would find the details for led codes. you may select any laptop. codes remain the same.
Sep 24, 2009 | Dell Latitude D600 Notebook
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Computer monitor flashes on then turns off
Try the monitor with another computer. If it works, the video circuitry (whether it is on-board or a separate adapter) in the Gateway is the problem and needs to be replaced. Otherwise, the problem is with the monitor itself. From your description it is probably the Gateway's video that is the problem since the power light on the monitor remains green indicating that it is seeng a signal, but not something it can properly interpret, i.e., one or more of the control signals are shot.
Mar 21, 2009 | Computers & Internet
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Xbox shuts off
It may actually be that your power box has failed or died. If so than you cant do anything really.Sorry.
Feb 10, 2008 | Microsoft Xbox 360 Console
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
155 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
